different classes in a repeat region
Thread begun 3/03/2017 5:24 am by Jamie | Last modified 3/06/2017 10:43 am by Ray Borduin | 2078 views | 4 replies |
Jamie
Hey Ray
Just wondering how I would set the 1st record in the below repeat to add a class
html:
class="responsive-picture mainGalleryImage"
to the image a href but then all the subsequent records to show
html:
class="responsive-picture thumbnailGalleryIMage"
<div class="galleryContainer">
while(!$Slideshow->atEnd()) {
<a href="#">
<picture><img alt="" src="img/picture-12.svg"></picture>
</a>
$Slideshow->moveNext();
$Slideshow->moveFirst(); //return RS to first record
</div>
Jamie
Dave BuchholzBeta Tester
Not Ray but this would be the easiest way to achieve what you want:
<?php $count = 0; // add count and set to zero ?>
<a href="#">
<picture class="responsive-picture <?php echo($count === 0)?'mainGalleryImage'?'thumbnailGalleryIMage'; // check count value and display appropriate class ?>"><img alt="" src="img/picture-12.svg"></picture>
</a>
<?php $count++; // increment count at end of each loop ?>
</div>
You simply add a count and then check it's value and display the appropriate css class.
Regards,
Dave Buchholz
I-CRE8 Limited
Jamie
many thanks Dave and much appreciated for taking a look.
Tried to use that but it seems that this echo statement
is erroring
Jamie
Bah, to early in the morning, the echo statement should read:
<?php echo($count === 0)?'mainGalleryImage':'thumbnailGalleryIMage'; // check count value and display appropriate class ?>
Regards,
Dave Buchholz
I-CRE8 Limited
Jamie
Youre a gem Dave and many thanks!
Jamie
