Misaligned data in repeat region
Thread begun 3/01/2017 11:08 am by iain331081 | Last modified 3/01/2017 5:36 pm by Ray Borduin | 2944 views | 5 replies |
iain331081
Not sure what I've done wrong here - in the page below Have a section listing Elements which can be added to days of a tour itinerary.
The first record appears OK, but when I added a second its indented by about 600 pixels - could you have a quick look to see if you can see what's causing it?
I've attached a copy the page.
Thanks.
Your activity: "Night game drives" is wrapped in a <p> tag, which gives it padding and prevents the next line from slipping below it.
Since you are displaying information in a table format it might make more sense to use table tags to ensure it displays properly.
iain331081
Thanks Ray - will have a look at using a <table> Think its one of those things that gets drummed out of you until you forget that sometimes table is actually what you need.
iain331081
Hi Ray - I'm just having trouble getting each subsequent day start on a new row aligned to the left.
I just added some table tags, and put the table row inside the repeat region.
And made the containing div to be 10 columns.
Also added a clear_both rule which just has:
clear: both;
overflow: hidden;
Which usually forces content to start below anything above it.
You had another <table> tag instead of the </table> tag.
iain331081
Sorry, thanks Ray - that's a howler.
