eCart - random blank order emails
Thread begun 3/01/2017 9:24 am by rob75685 | Last modified 3/16/2017 11:32 am by Ray Borduin | 1252 views | 10 replies |
rob75685
hi guys
I have eCart running on a site - www.earlyyearsdirect.com - for a few years now.
Occasionally something happens like this: the order receipt is received by email, followed by another 5 which are blank... see attachments.
Bit of a weird one as it doesn't happen every time. All emails have the same SagePay order no.
Any ideas to get me started ? Every time I test it works fine.
Thanks for your help as always
I could take a look. I'm not sure I could spot a problem, but I might be able to come up with a solution so that repeat orders wouldn't send repeat emails.
rob75685
hi Ray
Thanks for your help with this, I've attached the eCart files plus the checkout page which sends the email. Just let me know if there's anything really obvious that would cause repeat emails with empty orders.
The checkout page does forward on to another page (attached)
Let me know if you need anything else
Can I see the email body page? I'm going to add a check on the top of the checkout page to make sure the variables are set that are in the empty emails and not send when they are.
rob75685
hi Ray, yes of course - attached
thanks very much
WAUE_success_2.php
On line 97 of the checkout success page you have your trigger:
if (("" == "")) {
I see the cart is empty when you get the blank emails, so you can probably just update that to:
if ((!$eCart1->EOF())) {
And that will prevent them from sending out. I'm not exactly sure what would cause that intermittently, but this should be a viable solution.
rob75685
thanks Ray I'll drop this in place
rob75685
hi Ray
That's now had the effect of generating 20+ repeating emails with the order details...
I've had to revert back, so any other thoughts?
thanks
Rob
That doesn't make any sense. The original trigger is:
if (("" == "")) {
Which is essentially "always"
Updating the trigger to:
Means "if the cart isn't empty". I can't imagine any way that an added condition can cause more emails to be sent. Is there another page that might be sending the email?
rob75685
hi Ray
No... there's a second page that's directed to after the email post... but that has no scripts, see attached
