Confirm Form Resubmission
Thread began 2/28/2017 5:12 am by QuiruNet | Last modified 8/22/2019 1:06 am by anonymous | 8591 views | 6 replies |
QuiruNet
Hi, I have a problem, when I click on the ecart purchase button, everything goes well, but if I go to the basket, and then I click on the arrow to go back in the browser, always give this message:
This webpage requires data that you entered earlier in order to be properly displayed. You can send this data again, but by doing so you will repeat any action this page previously performed.
Press the reload button to resubmit the data needed to load the page.
ERR_CACHE_MISS
you can try: http://faitenotar.com/aventuras/aventuras_en_asturias_actividades.php?aventurasID=183#tarifas
That is because your add to cart doesn't do a redirect after. If you add a redirect to your add to cart, it can redirect back to the same page, but will prevent this error.
QuiruNet
info
do you mean?, it is a option in the Ecart?? like a button?,..where i can find it?
The add to cart server behavior has a redirect Go to Page option. If you set that then the back button won't cause a form resubmit error. Another option is to use a simple link for the continue shopping button instead of a history.back() reference.
QuiruNet
info
the add botton is here: aventuras_en_asturias_actividades.php
The basquet is here: tu-cesta.php
the retdirect must go to: aventuras_en_asturias_actividades.php....
in safari is working, bur firefox and chrome...doesnt work
I think the best solution will be to update your continue button to link directly to the page: aventuras_en_asturias_actividades.php. That will definitely fix it for all browsers.
anonymous
Fix Confirm Form Resubmission Error
This post has been deleted.
