readonly html editor
Thread begun 2/23/2017 2:53 am by mbunal | Last modified 2/23/2017 9:42 pm by Ray Borduin | 1036 views | 2 replies |
mbunal
it is possible to make readonly html editor? if yes how can be done?
Why use an html editor if it is read-only? You can probably use a <div> that looks like an html editor to make what would effectively be a read-only hmtl editor.
mbunal
i did not achieve to render dynamic page in a div. but html editor done it. now i want to just browse page. there is no edit , no save. just lookup. so i must use setReadOnly parameter of ckeditor.( http://docs.ckeditor.com/#!/guide/dev_readonly ) but i cant send to htmleditor 'config.readOnly = true;'
UPDATE:
$CKEditor_config["readOnly"] = true;
but at work;that code did not worked. now it works. interesting...
solved.
