Multiple Update Records???
Thread begun 2/22/2017 9:32 am by Steve | Last modified 10/19/2017 11:11 am by Ray Borduin | 2878 views | 5 replies |
Steve
Hello,
Where is this in the MySQLi methods?
That isn't currently available in MySQLi. You would have to manually wrap the code in a loop.
Accumike
Example Code
Hi Ray
Do you have a simple example of the Update code wrapped in a loop?
Here's my single record update code:
if (isset($_POST["WA_Update2"]) || isset($_POST["WA_Update2_x"])) {
$UpdateQuery = new WA_MySQLi_Query($crm_realpress_wa);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "cu_action_act";
$UpdateQuery->bindColumn("idusr_updater_act", "i", "".((isset($_POST["idusr_updater_act"]))?$_POST["idusr_updater_act"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("updated_act", "t", "", "WA_CURRENT_TIMESTAMP");
$UpdateQuery->bindColumn("active_act", "i", "".((isset($_POST["active_act"]))?$_POST["active_act"]:"") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("id_act", "=", "i", "".($_POST['id_act']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "timeline.php?id_usr=" . $_GET['id_usr'] . "";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
At present the addFilter is on id_act ($_POST['id_act'])
I would want to to run the loop where idusr_act = xx (this can be got from $_GET['id_usr']) and active_act=1
In effect this would set the active_act field to zero for all records selected in the loop.
Also, how would I trigger the loop?
Hope this makes sense.
I'm not sure that you need a loop if all of the records you are updating have the same value... is $_GET['id_usr'] an array you want to loop on?
You may just need:
$UpdateQuery->addFilter("active_act", "=", "i", "1");
Accumike
Block Update Works
Hi Ray
Thanks for the quick reply - yes this works very well. I added 4 addFilters (!) and it does a block update, just like I need.
I wasn't aware that you could have more than one addFilter - perhaps you could mention this in a future upgrade.
Thanks for your help.
You can do a lot with the library files that isn't exposed in the user interfaces. It just breaks the server behavior so you have to edit it by hand moving forward.
