Unable to Update or Insert Images
Thread begun 9/06/2009 1:01 pm by Daryl | Last modified 9/09/2009 9:42 am by Daryl | 10145 views | 16 replies |
DarylBeta Tester
Unable to Update Images
I have an Insert and Update page which I have tried to intergrate DFP to upload a logo.
I have been through the Video Tutorials and have also printed off the pdfs and have followed them through a couple of times but still can't get them to work.
Data is being inserted into the Database correctly, with the exception of the logo column.
I have attached them here for anyone to have a look at for me.
Thanks in advance
DarylBeta Tester
OK, I have had a look at code on another Insert page that I created some time ago that works...
It seems that it was the DFP form that I was getting wrong.....
In the original page I had;
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(isset(
$_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1""".((isset($_POST["unit_logo"]))?$_POST["unit_logo"]:"")  ."""2""[NewFileName]_[Increment]""PNG:5"$WA_UploadResult1_Params);
But I should have had this;
if(isset(
WA_DFP_UploadFiles("WA_UploadResult1""unit_logo""2""[NewFileName]_[Increment]""PNG:5"$WA_UploadResult1_Params);
The images upload, but the only problem now is that I am getting these errors:
  Warning: unlink(/home/sites/lsdogs.org.uk/public_html/Members/../images/unit_logos/3ddc849e072b9aec8473e02b496c76a3.png) [function.unlink]: No such file or directory in /home/sites/lsdogs.org.uk/public_html/WA_DigitalFilePro/HelperPHP.php on line 212
  Warning: Cannot modify header information - headers already sent by (output started at /home/sites/lsdogs.org.uk/public_html/WA_DigitalFilePro/HelperPHP.php:212) in /home/sites/lsdogs.org.uk/public_html/Members/Unit_Insert.php on line 94
DarylBeta Tester
I have tried running the DFP2 Beta but get the same results.
I have ensured that all folder are CHMOD 777 and have confirmed that the images are getting to the right folder....
anonymous
Daryl,
Just so I understand (in order to help better), is the file name making it into the database column?
Or, is the image being uploaded to your folder but the database not storing the name?
Or is neither happening?
Best regards,
Brian
DarylBeta Tester
Hi Brian
Now that I have changed the code on my page to replicate another that I made, the file is now uploaded and the file name is now uploaded to the page, however I get the two errors mentioned on my last post.
I have attached the latest code in case this helps.
DarylBeta Tester
Some additional info about the Update Page.
The Debug report says;
  Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
I also have the following error script running which does not display any errors;
error_reporting
(E_ALL);
The latest edition of this file is attached
DarylBeta Tester
Could this have anything to do with my SQL?
Originally it had a few SQL statements that I didn't recognise that kept throwing up errors. Things like the word param before user_id and things like that.
When I have been trying to get this working I tried going into the SQL to test things but it wouldn't let me do anything as it didn't recognise these statements.
So now they arn't there.....
anonymous
Daryl,
9 times out of 10, anytime you see that headers error, it is because of "white space" before or between php tags BEFORE the output of your page's html.
In other words if you had this, it would cause an error (notice the space between the php tags:
a bunch of code here
and there
<?php some more code ?>
Make sure all your pre-html PHP looks like this:
and there
Make sure there are no lines... you could even bring the start of the next PHP tag right after the close of the last one. This is where I would start first making sure there are no possible spaces between PHP tags or the beginning of the file... if it still gives the headers error, then we know to look elsewhere.
Best regards,
Brian
DarylBeta Tester
Thanks again Brian...
I have ensured that every PHP tag (both opening and closing) is touching the the previous or following tag in both the Insert and Update pages.
The insert page inserts alll of the text properly and also uploads the images and adds the file name to the database, but I get
  Warning: unlink(/home/sites/lsdogs.org.uk/public_html/images/unit_logos/802ea42c0bfcb804566d11edd96a9c62.png) [function.unlink]: No such file or directory in /home/sites/lsdogs.org.uk/public_html/WA_DigitalFilePro/HelperPHP.php on line 212
And with the Update page no file is uploaded and no file name is put into the database. The error codes that I get are;
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
On another note - It would be useful to have a pdf somewhere that explains the last set of error codes that I have uploaded (and all the others with that script) and a quick faq on things to try to resolve it.
DarylBeta Tester
The Insert now works!!!
It appears that my host does not allow 777 CHMOD due to security reasons, however the folder says that it is 777.
After changing it to 755 (the hosts suggestion) the Insert worked!!!!!
Its just the Update now.....
