IPN Verification Postback to HTTPS
Thread begun 2/21/2017 1:16 pm by Dave Buchholz | Last modified 9/14/2021 9:01 am by Ray Borduin | 4478 views | 6 replies |
Dave BuchholzBeta Tester
See https://www.paypal-knowledge.com/infocenter/index?page=content&id=FAQ1916&expand=true&locale=en_US
PayPal will be requiring post backs, which are controlled by the WA_isValidPayPal function to be to https from 30th June.
I am assuming that this part off the function:
$header = "POST /cgi-bin/webscr HTTP/1.1\r\n";
$header .= "Content-Type: application/x-www-form-urlencoded\r\n";
$header .= "Host: www.paypal.com\r\n";
$header .= "Content-Length: " . strlen($req) . "\r\n\r\n";
$fp = fsockopen ('www.paypal.com', 80, $errno, $errstr, 30);
Will need to be changed accordingly and from the url I posted I assume it will look like this ?
$header .= "Host: ipnpb.paypal.com\r\n";
$fp = fsockopen ('ipnpb.paypal.com', 443, $errno, $errstr, 30);
I am working with a live site so I want to make sure I get this right 1st time!
Thanks,
Dave Buchholz
I-CRE8 Limited
It looks like you need to add "ssl://" to the front of the url to use ssl for an fsockopen call. Other than that it looks correct.
I think you can still use www.paypal.com but if you read you should use ipnpb.paypal.com then that should work as well.
Thanks Ray, that advice is exactly why I ask here first before blundering in !
Just to follow up on this after testing changing the code to this worked:
$header .= "Content-Length: " . strlen($req) . "\r\n";
$header .= "Connection: close\r\n\r\n";
$fp = fsockopen ('ssl://www.paypal.com', 443, $errno, $errstr, 30);
for some reason no version of the code using the ipnpb.paypal.com domain would work
Regards,
Dave Buchholz
I-CRE8 Limited
Ray, apologies for resurrecting this old thread but it pertains to an issue this site has started experiencing recently. Whenever I get a IPN notification now it is producing a FALSE from the function so none of the orders are getting inserted into the database or a receipt generated. I have included in a private message what I see being returned and the full code that is being used. Are there any changes to the IPN system that I am not aware of ? I have not updated this code in 3 years so it must be a recent development.
Many thanks
It looks like we have updated the function at some point.
We now use:
function WA_isValidPayPal()     {
// STEP 1: read POST data
  // Reading POSTed data directly from $_POST causes serialization issues with array data in the POST.
  // Instead, read raw POST data from the input stream.
$raw_post_data = file_get_contents('php://input');
$raw_post_array = explode('&', $raw_post_data);
$myPost = array();
  foreach (
$raw_post_array as $keyval) {
$keyval = explode ('=', $keyval);
    if (
count($keyval) == 2)
$myPost[$keyval[0]] = urldecode($keyval[1]);
// read the IPN message sent from PayPal and prepend 'cmd=_notify-validate'
$req = 'cmd=_notify-validate';
  foreach (
$myPost as $key => $value) {
$value = urlencode($value);
$req .= "&$key=$value";
// Step 2: POST IPN data back to PayPal to validate
$ch = curl_init('https://ipnpb.paypal.com/cgi-bin/webscr');
curl_setopt($ch, CURLOPT_HTTP_VERSION, CURL_HTTP_VERSION_1_1);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $req);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 1);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 2);
curl_setopt($ch, CURLOPT_FORBID_REUSE, 1);
curl_setopt($ch, CURLOPT_HTTPHEADER, array('Connection: Close'));
// In wamp-like environments that do not come bundled with root authority certificates,
  // please download 'cacert.pem' from "https://curl.haxx.se/docs/caextract.html" and set
  // the directory path of the certificate as shown below:
  // curl_setopt($ch, CURLOPT_CAINFO, dirname(__FILE__) . '/cacert.pem');
if ( !($res = curl_exec($ch)) ) {
// error_log("Got " . curl_error($ch) . " when processing IPN data");
curl_close($ch);
    exit;
curl_close($ch);
  return (
strcmp ($res, "VERIFIED") == 0);
You could try updating it on your end and see if that fixes the problem. It looks like you have it manually updated on line 1332 of the eCart Definition include.
Thanks Ray, you are correct I put the previous new code in it's own function to a/b test and never moved it out. I have updated the file with the new code and I will let you know if there is still an issue.
