Call to a member function fetch_array() on a non-object
Thread begun 2/20/2017 4:54 pm by LionsMane | Last modified 2/21/2017 7:48 pm by Ray Borduin | 3344 views | 5 replies |
LionsMane
Pulling a standard recordset (no strange IF or WHERE requirements) from a View gives this error on the rsobj.php file. Any ideas why this might happen? Changing to query a table instead of the View retrieves data just fine. All the view is doing is pulling another related column from another table. Nothing special, AND this used to work, so I'm not sure why it's suddenly failing. Thoughts on what to look at?
Maybe view permissions preventing the view from returning data to that user? Do you have debug=true in your rsobj.php file? That should cause it to show more information about errors like this.
If you can give me ftp access and a url to reproduce the problem I can look into it further.
LionsMane
FTP info
Sending in PM
What page should I browse to in order to reproduce the problem?
LionsMane
URL to reproduce
In PM. If I change it to call to a table instead of a view, the error goes away.
I added some debug code and found that the error it was reporting is:
Errno: 1615
Message: Prepared statement needs to be re-prepared
I did some googling on that error and never found a good answer for the cause. I did see there may be an open mysql bug associated with it. It appears it may be a matter of increasing the "table_definition_cache" parameter on your database. But that may not be possible on a shared hosting environment.
I've "Fixed" the problem for now by updating the rsobj.php file on your server so that it doesn't use a prepared statement if no parameters are passed, and then updated your recordset to embed the parameter rather than pass it as a prepared statement. Unfortunately that will break inspection of the recordset on your page.
In the long term I may add a configuration option to the recordset to turn off prepared statements for people like you that run into this problem, but you will have to use the work-around for now. Make sure to download and save a copy of the rsobj.php file I updated in case you accidentally overwrite it.
