Search page pulling in incorrect data
Thread begun 2/07/2017 8:37 pm by EmmaMorris | Last modified 3/01/2017 3:21 pm by Ray Borduin | 9856 views | 58 replies |
EmmaMorris
I have a search page that I am working on. See previous post 'Update page to modify database' for basic info. Created back end, works great.
The fields that are having an issue are ones that are using an array. This is probably simple as I see what it is doing.
Will use one specific field. Specialties. They can be numbered from 1 to about 25.
record 1 has 1,3,5 for entries
record 2 has 1, 7, 13 for entries.
When I search for specialty 1 both records come up.
When I search for 7 #2 comes up.
5 #1 comes up
but.... when I search for 13 or 3 I get both. I assume it is because they both have numbers in common. I also assume somewhere there should be something that tells it to use the comma separator to split it up.
Here is the comparison list line from the results page
$WADbSearch1->addComparisonFromEdit("specialtiesID","specialtiesID","AND","Includes",0);
or is the problem on the search page?
Thanks.
Any help would be appreciated.
Gary.
Are the numbers comma separated or comma-space separated? Hopefully it is consistent and then I think I can give you a solution to this problem based on the answer.
EmmaMorris
There are 3 fields in each record that are those type arrays. They are all comma separated. No spaces.
I assume the fix is to use explode but I just cant quite get it..
Thanks.
Gary.
The solution is to use a comparison list like this:
$WADbSearch1->addComparisonFrom("specialtiesID","". $_GET["specialtiesID"]. ",","OR","Begins With",0);
$WADbSearch1->addComparisonFrom("specialtiesID",",". $_GET["specialtiesID"]. "","OR","Ends With",0);
$WADbSearch1->addComparisonFrom("specialtiesID",",". $_GET["specialtiesID"]. ",","OR","Includes",0);
$WADbSearch1->addComparisonFromEdit("specialtiesID","specialtiesID","OR","=",0);
Another solution that could work is to create a View in your database with something like:
SELECT Column1, Column2, etc, Concat(',',specialtiesID,',') AS specialtiesWrapped FROM Table
Then you would be able to use just this comparison:
You probably don't want to hear this part, but the reality is that you probably shouldn't be storing the values comma separated to begin with. Those should probably be separate rows in a relational table design particularly if you are searching against them. Storing numbers comma separated in a varchar field is not an efficient solution and wouldn't be suggested in the first place.
EmmaMorris
Thought I replied already to this but its not here so I will repost.
Thanks for the info. Will check it out.. Actually I would like to do it correctly. I have searched around and read a bunch and am getting more confused.
From what you are saying and what I am reading, I need a 3rd table, correct? mainID (the dr) and specialtyID(the specialty). Many to many relationship. Problem I will have is then I will have to change the back end to get them into the database correctly. How do I insert them into the db.
Then on the search end, will the WA extensions do that?
Hopefully this is the correct way to do it.. Would rather get it right from the beginning.
Thanks so much.
Added after trying above.. after adding the
29 $WADbSearch1->addComparisonFrom("specialtiesID","". $_GET["specialtiesID"]. ",","OR","Begins With",0);
30 $WADbSearch1->addComparisonFrom("specialtiesID",",". $_GET["specialtiesID"]. "","OR","Ends With",0);
31 $WADbSearch1->addComparisonFrom("specialtiesID",",". $_GET["specialtiesID"]. ",","OR","Includes",0);
32 $WADbSearch1->addComparisonFromEdit("specialtiesID","specialtiesID","OR","=",0);
I get this:
Fatal error: Call to undefined method FilterDef::addComparisonFrom() in public_html/mdb/results.php on line 29
Sorry I had a typo. It should have been:
29 $WADbSearch1->addComparison("specialtiesID","". $_GET["specialtiesID"]. ",","OR","Begins With",0);
30 $WADbSearch1->addComparison("specialtiesID",",". $_GET["specialtiesID"]. "","OR","Ends With",0);
31 $WADbSearch1->addComparison("specialtiesID",",". $_GET["specialtiesID"]. ",","OR","Includes",0);
EmmaMorris
Great that worked. He needs to show it to someone in a few days so at least it will work.
I will start checking the other out to make the change.
Was I correct with the Many to Many?
Thanks.
I think technically it would be a one to many.
We have extensions to help.
We have an "Insert Multiple Records" server behavior you can use on your insert page to insert the multiple records into the relational table on the insert page.
On the update page you would use our "Manage Relational Table" extension.
EmmaMorris
ok. If I have a dr ... mainID1 who can have multiple specialties specialtiesID 1,2,23 I could understand that.
but if many other drs can have the same specialtiesID's . Wont that require a separate table to store the data.
dr spec
1 1
1 2
1 23
2 1
2 23 etc
Isnt that a many to many? I cant see how the add page which is setup with a checkbox for each specialty will work with your multiple record insert.. What am I missing?
Thanks.
