Validation is not working, I have entered a value but getting error
On my new insert page I am getting an error that the required field domain is not filled it but I have filled it in.
You have validation on other fields that might be causing it to fail as well.
To determine the exact field write this to the page:
if (isset($_SESSION['WAVT_sitesndetailsinsert_Errors'])) echo($_SESSION['WAVT_sitesndetailsinsert_Errors']);
That will tell you the error number(s) when validation fails and help you narrow down which field caused the error.
