Sending a form variable to the same page for recordset lookup
Thread begun 2/03/2017 8:14 am by rob75685 | Last modified 2/03/2017 12:41 pm by Ray Borduin | 615 views | 1 replies |
rob75685
hi guys
So I have a form which when posted is Inserted into a MySQL database.
The redirect is the same page with a success message on it.
I want to be able to display the ID of the inserted record on that same page afterwards.
I've tried posting a session variable, then setting the recordset to retrieve a record based on the session, and I've also tried setting the recordset to retrieve a record based on the POST value... but I'm getting stuck
Can you point me in the right direction please ?
many thanks
You should be able to just display it directly from the session variable set during the insert. You may need to start the session on the top of the page to make sure it is accessible:
@session_start();
