<i></i> tag being stripped out of PowerCMS areas?
Thread begun 2/01/2017 6:53 am by Mags | Last modified 2/02/2017 2:13 pm by Ray Borduin | 1870 views | 4 replies |
Mags
I use standard Font Awesome classes to style bulleted lists, like this:
<ul class="fa-ul">
<li><i class="fa-li fa fa-check"></i>List item</li>
</ul>
When this code is used within a PowerCMS editable area, it initially displays OK but as soon as I try to Edit the region (and before I've actually made any edits), if I look at the Source code the <i> tags have disappeared so I'm left with this:
<ul class="fa-ul">
<li>List item</li>
<li>List item</li>
<li>List item</li>
</ul>
Any way I can stop this from happening?
This may be fixed in a more recent version of the html editor. If you give me FTP access and a url where I can reproduce the problem I can see if updating to a newer version will fix it.
Mags
Hi Ray, that would be great thanks - details in PM section.
Updating the ckeditor didn't help. However I was able to find a solution. I added this to the webassist/ckeditor/config.js file:
CKEDITOR.dtd.$removeEmpty['i'] = false;
That seems to have corrected the problem.
Mags
That's great thanks Ray, it's done the trick. I have one CMS governing several separate related sites so I'll copy this file over to the other sites too.
