Menu selection if validation fails
Thread begun 1/27/2017 6:32 am by bjgarner241692 | Last modified 1/30/2017 12:21 pm by Ray Borduin | 1411 views | 3 replies |
bjgarner241692
When validation fails, my text fields remain filled with this code.
<input id="HomeName" name="HomeName" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("residenceinsert","HomeName"):"")); ?>" class="formTextfield_Medium" tabindex="6" title="Please enter a value.">
if (ValidatedField('residenceinsert','residenceinsert')) {
if ((strpos((",".ValidatedField("residenceinsert","residenceinsert").","), "," . "5" . ",") !== false || "5" == "")) {
if (!(false)) {
My dropdown menu selections however return to the default. Between the default value and the dynamic values I am not sure how to get the drop down to return to the entered value as with the text field.
<select name="agent" id="agent">
<option value="None" <?php if (!(strcmp("None", ((isset($_POST["agent"]))?$_POST["agent"]:"")))) {echo "selected=\"selected\"";} ?>>None</option>
do {
<option value="<?php echo $row_agents['Agent']?>"<?php if (!(strcmp($row_agents['Agent'], ((isset($_POST["agent"]))?$_POST["agent"]:"")))) {echo "selected=\"selected\"";} ?>><?php echo $row_agents['Agent']?></option>
} while ($row_agents = mysql_fetch_assoc($agents));
$rows = mysql_num_rows($agents);
if($rows > 0) {
mysql_data_seek($agents, 0);
$row_agents = mysql_fetch_assoc($agents);
</select>
if ((strpos((",".ValidatedField("residenceinsert","residenceinsert").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<span class="serverInvalidState">Field is Mandatory </span>
<?php //WAFV_Conditional residence_insert.php residenceinsert(3:)
For the select list replace:
with:
<?php if (!(strcmp($row_agents['Agent'], ((isset($_GET["invalid"])?ValidatedField("residenceinsert","agent"):"")))) {echo "selected=\"selected\"";} ?>
For inputs with a default you can use:
<input id="CareIndependant" name="CareIndependant" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("residenceinsert","CareIndependant"):"U")); ?>" class="formTextfield_Medium" tabindex="20" title="Please enter a value.">
bjgarner241692
Thank you.
I have the same issue with my update page.
<option value="<?php echo $row_WADAresidence['agent']; ?><?php if (!(strcmp($row_WADAresidence['agent'], ((isset($_POST["agent"]))?$_POST["agent"]:"")))) {echo "selected=\"selected\"";} ?>><?php echo $row_WADAresidence['agent']; ?></option>
        <option value="None">Clear</option>
do {
Following from your suggestion on the insert page I can see that I need something like this:
((isset($_GET["invalid"])?ValidatedField("residenceupdate","Agent"):"".$row_WADAresidence["Agent"].""))
but I cannot seem to get it two work.
<?php if (!(strcmp($row_agents['Agent'], ((isset($_GET["invalid"])?ValidatedField("residenceupdate","agent"):"")))) {echo "selected=\"selected\"";} ?>
