html editor site-settings connection problem
Thread begun 1/25/2017 10:33 am by Marga-NL | Last modified 2/24/2020 9:38 am by Ray Borduin | 4031 views | 10 replies |
Marga-NL
When I click the 'define' button next to the Connection field, the right (mysqli)connection shows, but this connection doesn't show in the list after clicking 'done' (or 'choose', I work with a dutch version). 'none' remains the only option. The alert 'please choose a connection' keeps popping up.
Dreamweaver can do this occasionally. You may need to close and re-open the interface, click the refresh button in the databases panel, close and open the page, or even restart Dreamweaver to get the connections to show.
Marga-NL
Did that several times, without result. The problem seems to be the mysqli connection. I made an old fashioned mysql connection and that works fine. Then I changed in the kfm folder in the connection file the new mysql connection to the mysqli connection. Now it works. But why is this even necessary at all?
I didn't realize you were using a mySQLi connection. The HTML editor hasn't been updated to work with MySQLi, so that is why it doesn't show in the list.
Marga-NL
Will the editor be updated in future or is it deprecated? Do I have to find another solution for future implementation? I use the editor quite often in cms for my customers.
We will be using a different file manager in the next release that won't have any database dependencies at all. The current html editor doesn't actually use the mysql connection directly. It just uses a mysql connection file to get the credentials. I think it uses mysqllite behind the scenes. You just have to create a mysql connection file for it to read the username, password, and database from.
Marga-NL
Thanks for your feedback. Hopefully this update will be released soon. I'm sorry, but I encountered one more problem: in the file folder within the html editor the thumbs won't show (see attached file). This is the first time I ever had this problem. When I choose an image however, everything works fine. For over two hours I've been searching webassist folders and files to manage the problem, no luck. You see, I am not a developer, just a designer who knows a bit about code and implementing a custom cms.
I'd need FTP access and a URL to reproduce to debug this. It could be something as simple as an extra blank line in one of the files.
Ido
info
see pm
Eric
I am having the same issue. I need to convert my code from MySQL which is throwing out a mysql decprecated error. I purchased the webassist product to update my code. When I click define - I have a connection defined and it connects successfully. When I click okay I have none as the connection text. I knew how to put together data driven websites in dreamweaver. This seems the same but I can't get past the connection issue. Is there a different web authoring tool you would suggest? I am usinfg the latest dreamweaver CC.
