Filter a recordSet by year using the date column
Thread begun 1/20/2017 7:56 am by s.joiner74419001 | Last modified 1/23/2017 12:34 pm by Ray Borduin | 2273 views | 3 replies |
s.joiner74419001
I have a recordSet that selects two columns ( snippet , date [ yyyy-mm-dd ] ) from a NEWS database table. I am using the recordSet to create a list using a repeat region. I would like to be able to filter the list by year from a dropdown that sits above the list. I have been trying to use the 'DataAssist Search Behaviour' to achieve the task but can not work out how. I have managed to get a filter working but only as a comparison 'Less or equal to' that uses a parameter in a url. But I would need to filter between to dates to cover a year.
Any pointers please.
Ive attached page so you can see what I have tried so far.
thanks in advance
There are probably a couple of ways you could do it, but one option would be to use something like:
$WADbSearch1->addComparison("date","".isset($_GET['year']?"1/1/".$_GET['year']:"")  ."","AND",">=",2);
  $WADbSearch1->addComparison("date","".isset($_GET['year']?"12/31/".$_GET['year']:"")  ."","AND","<=",2);
and then just pass the ?year=2017 or whatever year in the url. You would want to also update the if statement of the filter to:
if (isset($_GET['year'])) {
s.joiner74419001
Thanks Ray.. this is just the job!!
I would also like to have another option to flip the list between oldest or latest by date.
I realise I can achieve this if i used a table with the 'sort behaviour'
But the list I'm filtering is in an 'unordered list'. So is there another way I can do this?
Thanks in advance.
It might be possible to find a jquery option to do the sort of the unordered list in javascript, but I've always done it with the recordset and sorting that way.
