Column 'county' in where clause is ambiguous - error when adding 'DataAssist Search Behaviour'
Thread begun 1/19/2017 8:20 am by s.joiner74419001 | Last modified 7/18/2017 7:54 am by Ray Borduin | 4364 views | 6 replies |
s.joiner74419001
I a trying to manually add a 'DataAssist Search Behaviour' to a page but I am getting this error when I have added it.
'Column 'county' in where clause is ambiguous'
I am hoping to eventually have 3 filter options which will be - "View By - 'county' , 'agent' and 'All'.
But for now I just want to get the first filter working form the 'county' column in the recordset.
Page attached... Thanks in advance.
s.joiner74419001
OK so I have just realised that the problem lied with the two tables ( properties, agents ) being used in the recordset both have a column named 'county'. So I changed the 'county' column in the 'agents' table to 'county_a'. which solved the error.
What I don't understand is the 'county' column from the 'agents' table wasn't being selected in the recordSet. as below -
mysql_select_db($database_Testing_server, $Testing_server);
$query_rsRTMs = "SELECT properties.property_id, properties.property_name, properties.address, properties.town_city, properties.county, properties.`size`, properties.type, properties.acquisition, properties.image, properties.agent_id, properties.alt_tag, properties.title_tag, agents.agent_id, agents.name, agents.url FROM properties, agents WHERE properties.agent_id = agents.agent_id ORDER BY properties.acquisition ASC";
setQueryBuilderSource($query_rsRTMs,$WADbSearch1,false);
$rsRTMs = mysql_query($query_rsRTMs, $Testing_server) or die(mysql_error());
$row_rsRTMs = mysql_fetch_assoc($rsRTMs);
$totalRows_rsRTMs = mysql_num_rows($rsRTMs);
So how is it appearing in the column list from the filter options?
Filter is now working. using the following repeat region to filter the 'county' column.
// RepeatSelectionCounter_2 Begin Loop
$RepeatSelectionCounter_2_IterationsRemaining = $RepeatSelectionCounter_2_Iterations;
while($RepeatSelectionCounter_2_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_2 || $row_rsCounty){
<li><a href="right-to-manage-success-t.php?county=<?php echo $row_rsCounty['county']; ?>"><?php echo $row_rsCounty['county']; ?></a></li>
} // RepeatSelectionCounter_2 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_2 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_2 && $RepeatSelectionCounter_2_IterationsRemaining != 0){
if(!$row_rsCounty && $RepeatSelectionCounter_2_Iterations == -1){$RepeatSelectionCounter_2_IterationsRemaining = 0;}
$row_rsCounty = mysql_fetch_assoc($rsCounty);
$RepeatSelectionCounter_2++;
} // RepeatSelectionCounter_2 End Loop
I now want to use a second repeat region to filter the 'agents' column.
I think I need to hand code this just not sure how.
Current page attached
Thanks in advance.
s.joiner74419001
OK So I figured out how to add the second filter using a second trigger by referring another project using a similar technique and manually updating the trigger code as follows.
if (isset($_GET['county']) || isset($_GET['agent'])) {
What I need now is for the page to show all by default or once a filter has been selected to be able to revert back to 'view all'
I have a button on the page such as:
<a href="right-to-manage-success-t.php" role="button"> View All </a>
But I'm not sure how I can add a parameter to this and then add a third filter to the search behaviour for this to work.
You just have to re-trigger the search, so I think this would work:
<a href="right-to-manage-success-t.php?agent=" role="button"> View All </a>
s.joiner74419001
Ray, I now have the same 'show all' issue with another page using a similar search function. I have tried to adapt the same solution to 're-trigger the search' but this time it is not working properly. I am not having a 'View All' button but I need the same function when someone is directed to the page from the main nav-bar.
I've attached the page. You can also view it from the link in private section.
It appears to be working. What steps should I be following to see the problem? How can I tell it is or isn't working properly?
s.joiner74419001
Sorry Ray, Ive just realised my mistake on the Query. I had a RIGHT JOIN with counties instead of LEFT JOIN so it was repeating the region for all counties and not just for counties that matched with testimonials.
All working now.. Apologies.
