dropdown filter
Thread begun 1/16/2017 10:40 am by Jamie | Last modified 1/23/2017 12:10 pm by Ray Borduin | 2221 views | 7 replies |
Jamie
dropdown filter
hey Ray
On the attached page the default results returned are listed by category (mens, womens or childrens at the moment) from the productcategories table
I want to allow the user to then filter using the dropdown based on brand name (from the productmanufacturers table) so that it will show only mens, for example and then by brand name.
How wouold I do this with the RS and search/filter o sort?
If you give the list a name you should be able to check for that list name as a trigger and define a filter for the recordset. Where are you getting stuck?
Jamie
these bits:
Currently your list uses the code:
<select class="select filterBy">
It will need a name attribute to refer to it after submit.
Something like:
<select class="select filterBy" name="filterBy">
Then you can use the $_POST['flterBy'] value in an IF statement and in the search code to do the filter.
Jamie
OK, have tried setting the search up using:
$searchProducts_1 = new WA_MySQLi_Search("Categories","");
if ((isset($_GET["WADbSearch1"])) && ($_GET["WADbSearch1"] != "")) {
$searchProducts_1->clearSearch();
$searchProducts_1->setSearch(array("type"=>"k","comparison"=>"like", "and"=>" "), array("ManufacturerName"), "c", "".((isset($_POST["FilterBrand"]))?$_GET["FilterBrand"]:"") ."");
if ((isset($_GET["FilterBrand"])) && ($_GET["FilterBrand"] === "")) {
$searchProducts_1->setSearch(array("type"=>"v","comparison"=>"="), array("ProductSKU"), "s", "donotshowresults");
@session_start();
if (isset($_GET['FilterBrand'])) {
$_SESSION["FilterBrand"] = $_GET['FilterBrand'];
but a) it stops the unfiltered results from showing
and
b) the dropdown doesnt do anything
have atatched the page
Your form action is set to POST and you are using GET in your trigger and filter code. Those would have to match.
Jamie
ok am getting there....
I have added a submit button to trigger the option but
1) how do I get it to trigger without the button
2) no results are being returned
fresh version of the page attached
You can use javascript and the onchange event of the list to automatically submit the form and then trigger off the select list itself instead of the button.
You will have to debug the search returning no results. Maybe dump the recordset to the body of the page above the results and see what the final query is and see if you can spot the problem:
var_dump($RecordsetName);
