I cannot get the map to display
Thread begun 1/16/2017 4:16 am by georgina_barrett_187762 | Last modified 1/17/2017 3:40 am by Ray Borduin | 1013 views | 4 replies |
I am trying to set up pro maps. I am just setting up a test one to start with but I cannot get the map to show. I have looked through all the other posts but I cannot fix it. I have tried using an address and coordinates and I have made sure all files are uploaded. The address is https://asociacionecovida.es/test.php
Google recently updated their requirements. Now you need to enable both the maps and geo-location APIs from your google profile associated with the API key you are using. My guess is that you haven't enabled the geo-location api for this account.
Thank you, I have enabled all 16 API's within the Google Maps API section but still the map is blank.
You are viewing the page from https but the script tag has:
<script type="text/javascript" src="http://maps.googleapis.com/maps/api/js?sensor=false&key=AIzaSyCKfoV25JMUcmjEiSA8wgm98ABS4I-1mRQ">/*wagmp*/</script>
Try updating the script src to https:// to match the page.
That was it! Thank you
