Syntax to specify default sort order for a table with columns
In the code there is a line:
$WADA_Sort_1->DefaultSort = "";
If i wanted to set the default sort order, what would the syntax be?
I think it would be:
$WADA_Sort_1->DefaultSort = "ColumnName ASC";
Thanks Ray - that's giving me a syntax error on the page blow.
Try:
$WADA_Sort_1->DefaultSort = "ORDER BY Lodge ASC";
