My index.php on website does not work any more
Thread begun 1/06/2017 6:04 pm by cicyou421883 | Last modified 1/09/2017 5:54 pm by Ray Borduin | 2883 views | 5 replies |
cicyou421883
californianatural.store is not showing the index.php anymore since I added DataBridge and e-cart6. It was working before with older Webassist pages. The old php pages are deleted and not I cannot get my home page. A could of days ago I purchased the DataBridge and e-cart 6.
If you add this to the top of the page it will probably give you more information about why the page isn't displaying:
ini_set('display_errors',1);
If you can give me a url and ftp access to debug myself I could help. It is likely you just need to upload the /webassist folder.
cicyou421883
Response to blank index page
I added:
Index.php is on the remote server, URL - californianatural.store seems to load, however it is blank and nothing shows yet.
The new /webassist folder was uploaded as well.
I'm a bit confused. The index page appears blank on the web site. What do you expect to see on it?
Where you redesigning the site? What changes were you making? If you have accidentally overwritten your home page with a blank version you may be able to contact your hosting provider and get a backup from a few days ago to revert.
cicyou421883
WA_eCart
I modified the PHP to be current and eliminated the variables that e_cart object was using on my californianatural_PHP.php page. The home page then showed up fine. (I have back-ups on the home page I can access or recreate from a template)
I added the eCart Object again and the errors reappear. The error messages are coming up with the WA_eCart Object. I tried to reload and upload the complete file, but error messages are appearing. Here is my FTP private information.
Please advise.
I had to update line 43 of WA_eCart_Definition_PHP.php from:
function __construct(
function WA_eCartDefinition(
Which is an older style syntax that should essentially mean the same thing. Maybe this is an issue with the specific version of PHP you are running. This should fix the problem, but if you update your cart object it may overwrite my update. Please note this fix and/or save a backup of the file in case you run into this issue again.
