CSV Import
Thread begun 1/05/2017 10:12 am by Steve | Last modified 1/06/2017 2:41 pm by Ray Borduin | 2647 views | 3 replies |
Steve
CSV Import
Hello,
I have a condition where we have three linked tables and want to Insert and Update if the record already exists.
Is there anything available to assist on this level?
It seems I can do this via DMXzone extensions but I am much more familiar with WebAssist and I like the generated code rather than the javascript from DMX.
Anyone achieve this goal and have links to a tutorial etc?
The eCart server behavior for Store Cart Summary in database will do this. It should work for both MySQL and MySQLi connections.
Dave BuchholzBeta Tester
Steve,
I have used a library called PHPExcel to do this, you can download it here: https://github.com/PHPOffice/PHPExcel
Stack Overflow has lots of info on how to achieve this http://stackoverflow.com/questions/tagged/phpexcel
There is a function in php that will read a csv file into an array: fgetcsv()
It is relatively easy to upload a file and then read its content directly using that function.
