Add CMS area to email script?
Thread begun 1/05/2017 9:09 am by Mags | Last modified 3/30/2021 2:05 pm by Ray Borduin | 6746 views | 13 replies |
Mags
I have an automated email response set up on a web form on a site using PowerCMS. I'd like to allow CMS users to update the text when the office is closed, but not sure of the correct syntax to include a CMS area in the email script file - something like this but it contains a syntax error:
$MailBody = $MailBody . "</style><head></head><body> "echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Email Text', 'Text')"\r\n";
Can you help?
$MailBody = $MailBody . "</style><head></head><body> " . WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Email Text', 'Text') . "\r\n";
Mags
Fantastic service as always, many thanks Ray!
Mags
Hi Ray, following on from the thread above, I recently updated the site to use the new PowerCMS with mySQLi behaviors. I would still like to include a CMS area in the email - how would I update the code so that it works correctly?
I think it is the same. If you get an error or it doesn't work I might need FTP access to debug it.
Mags
Hi Ray
Looking at this again, I can see that because Universal Email has updated the way it works too, this is now set up differently. Previously I included the above line in the email script but now the body of the email is contained in a separate file, so the script looks like this:
$Email->BodyFile = "webassist/email/email-confirmation.php";
However if I try to include a PowerCMS area in the email-confirmation.php file it throws up errors. I tried including the full line from the developer notes:
<?php echo(require_once("/var/www/vhosts/mydomain.co.uk/httpdocs/WA_CMS/WA_CMS.php")); ?>
<?php echo(WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Shared Email Text', 'Text', false)); ?>
Also tried including the full path to the db connection file: <?php require_once('/var/www/vhosts/mydomain.co.uk/httpdocs/Connections/PowerCMSConnection_i.php'); ?>
Example of errors below:
Deprecated: filter_var(): explicit use of FILTER_FLAG_SCHEME_REQUIRED and FILTER_FLAG_HOST_REQUIRED is deprecated in /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/email/phpmailer/src/PHPMailer.php on line 3632
Notice: Undefined variable: PowerCMSConnection in /var/www/vhosts/mydomain.co.uk/httpdocs/WA_Globals/WA_Globals.php on line 42
Fatal error: Uncaught Error: Call to a member function query() on null in /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/mysqli/rsobj.php:213 Stack trace: #0 /var/www/vhosts/mydomain.co.uk/httpdocs/WA_Globals/WA_Globals.php(44): WA_MySQLi_RS->execute() #1 /var/www/vhosts/mydomain.co.uk/httpdocs/WA_CMS/WA_CMS.php(5): require_once('/var/www/vhosts...') #2 /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/email/email-confirmation.php(7): require_once('/var/www/vhosts...') #3 /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/email/WA_Email.php(315): require('/var/www/vhosts...') #4 /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/email/WA_Email.php(476): WA_Email->getFromPage('webassist/email...') #5 /var/www/vhosts/mydomain.co.uk/httpdocs/shared/email-script.php(97): WA_Email->send(0) #6 /var/www/vhosts/mydomain.co.uk/httpdocs/counselling.php(11): include('/var/www/vhosts...') #7 {main} thrown in /var/www/vhosts/mydomain.co.uk/httpdocs/webassist/mysqli/rsobj.php on line 213
I've attached the current email script and also the email content file. I've had to put everything back the way it was on the site because it's a live site, but let me know if you still need access, or I'm hoping there might be something obvious in the above or the attached files that I've missed!
Change the require_once() references in the email body to just require().
Then you may need to update DataBridge to get the latest version of the include files to get rid of the Deprecated messages. You could also just add this to the top of the page for now:
error_reporting
(E_ALL E_DEPRECATED);
Mags
Changing it to require() worked, although for some reason it's adding a "1" to the start of the email so it looks like this:
1
Thank you for submitting a query via our website...
I've checked both the PHP file and the CMS contents and there's no "1" in it - any idea what might be causing that?
Is that text from the CMS? Can I get FTP access and a url to debug? It could be a bug in the cms code.
Mags
Yes, it's from the CMS - have checked there and also in the email-confirmation.php file. FTP details in PM section.
