form security
Thread begun 12/29/2016 8:14 pm by David | Last modified 1/16/2017 11:10 am by Ray Borduin | 3518 views | 7 replies |
David
form security
I am trying to create a form with Captcha or a Security question and no matter what I do it will not validate. I have removed and reinstalled my extensions and am trying this in a clean .php document where there is only the form. Fails with edge or explorer or chrome. view at www.testing.montanasquaredancing.com/formtest.php. If I remove the security the form will process.....
I'll need a copy of the .php page to see what the problem is.
David
See attached
The security question answer session variable should just be: <?php echo($_SESSION["random_answer"]); ?>
So line 13 should read:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["General_Questions_group_2_Security_Question_2"])?$_POST["General_Questions_group_2_Security_Question_2"]:"")) . "",($_SESSION["random_answer"]). "",true,3);
David
Ray,
Thanks that works. But weird how the script wrote in both the Captcha and Security question validation info..
Are there going to be any updates to the Dreamweaver Suite anytime soon to address these types of bugs....
Dave
How did you add the security question? From Form Builder? If I can figure out how to reproduce the bug I can get it logged and fixed.
David
Sorry about the delay in reply. Yes, everything was added/done from the Form Builder.
I've run some tests and it appears to create the correct code for me. What steps did you use? Is this with the latest version? I'll need steps to reproduce in order to fix the issue in the product. Once I can reproduce the problem I can usually fix it.
