Can SiteAssist do this?
Thread begun 9/05/2009 1:59 pm by duncanwil312020 | Last modified 9/08/2009 9:55 am by duncanwil312020 | 3192 views | 2 replies |
duncanwil312020
I have just been looking at the Thomas Pink shirt and tie site and came across a feature I've never seen before. You can see it here, I hope: 99911322
I took a look at the source code and the roll over magnification is done by JavaScript I think. Can SiteAssist and DWCS4 do this ... if so, how? I reckon I can use this feature from time to time.
TIA as always.
Duncan
Justin Nemeth
You can use SiteAssist Pro to set up the general look for your page, but the javascript image zoom would have to be implemented by hand after generating your pages from SiteAssist. That is definitely something Dreamweaver is able to handle, it would likely involve linking in some external javascript files and adding some javascript to the page you apply this effect to.
By looking at the source code, it looks like it uses mootools (mootools.net) as the base javascript framework, then a plugin called frescaZoom.
-justin
duncanwil312020
Thanks Justin
Thanks for taking the time to look into it for me.
I might write to their webmaster and try to pick his brains too.
Duncan
