Someone managed to get past server side validation
This post has been deleted.
Are you using the exact same trigger for the email and the server validation? Do you have a copy of the page I can see?
Hi Ray, turned out I didn't have server validation on at all - the problem was caused with two fields using the "required" flag which apparently is not recognised by Safari. I've added jQuery validation as a quick fix and will also add server validation as soon as I get a chance.
