datepicker: how to set mindate and maxdate from mysql?
Thread begun 11/18/2016 2:14 am by tony | Last modified 11/25/2016 3:27 pm by Ray Borduin | 8738 views | 13 replies |
tony
Hi all,
I have a form with a select and a text input field (datepicker).
The select is populated from a mysql db.
Based on selection, I should create a recordset; the resulting recordset will contain a mindate and a maxdate in mysql format.
In the same form I have an input filed set as datepicker.
I would like the datepicker to show only the days between the mindate and the maxdate.
How can I do this?
TIA
tony
You can update the javascript manually and set a minDate and maxDate for the datepicker. See: http://api.jqueryui.com/datepicker/
tony
I already set the mindate and maxdate manually, but I would like to get it dynamically, from php+mysql.
I would like the user to select an item from a dropdown menu. Based on dropdown selection a recordset will get 1 record from a database.
This record will contain min and max date.
The datepicker should read mindate and maxdate from this recordset.
I think I need to use ajax but I'm a newbie about it, since the recordset will be executed only after the form will post.
But I can't find a way to do this.
Any suggestion?
TIA
Tony
You can add a recordset to the page to get the mindate and maxdate and then use the bindings panel to set the value on the page from the recordset in place of the manual code you have already added.
tony
I already tried this, but keep in mind that this should occur on the same page without reloading it.
How can I get the selected value after selecting an item from a dropdown menu populated by a recordset and use it on the same page without reloading?
Do this need ajax in any way?
TIA
tony
tony
Just to make things simpler I decided to not set valid dates in datepicker and leave the user the ability to choose any date.
But now I would like to validate the date inserted against the values that are generated from a recordset . This recordset filters a table based on the selection made on a dropdown menu on the same page and gets 1 record with the mindate and maxdate fields (along other fields).
But it seems that this doesn't work.
Tony
tony
ok, I'm near to the solution.
It didn't workbefore because the WA validation code was above the recordset code.
Now I moved the recordset code below the WA validation code and now it works.
The only thing that I would like to make it work is to display MINDATE and MAXDATE in the validation error message.
I simply put the binding from the recordset in the error message, but it displays empty).
Tony
That should work. If you give me a copy of the page I could look at what is wrong.
tony
Hi Ray,
I replied with a private message.
Tony
The issue is that you are filtering the recordset based on the posted value and failing validation removes the posted value.
The solution is to set the default value to the persisted form value on line 98 like:
$colname_rs_validata = WA_getSavedFormValue("persist_data","tipo_punto_vendita_reg")?WA_getSavedFormValue("persist_data","tipo_punto_vendita_reg"):"-1";
That should allow you to drag from bindings.
