set cookie to remember language choice
Thread begun 11/11/2016 10:29 am by Mags | Last modified 6/21/2018 9:44 am by Ray Borduin | 8707 views | 8 replies |
Mags
I have a dual language website (English/Russian) which has a language selection dropdown in the header of every page:
<ul>
<li class="active"><a href="/en/<?php echo basename($_SERVER['PHP_SELF'])?>">ENGLISH</a></li>
<li><a href="/ru/<?php echo basename($_SERVER['PHP_SELF'])?>">РУССКИЙ</a></li>
</ul>
Visitors are currently automatically redirected to domain.com/en/ via the .htaccess file:
RewriteCond %{HTTP_HOST} ^(www.)?domain.com$
RewriteRule ^(/)?$ en [L]
If the visitor then chooses Russian, how would I go about setting a cookie to remember this choice for their next visit? Would I
need to alter the .htaccess file as well?
You could add another url parameter to trigger the cookie setting like:
<ul>
<li class="active"><a href="/en/<?php echo basename($_SERVER['PHP_SELF'])?>?lang=en">ENGLISH</a></li>
<li><a href="/ru/<?php echo basename($_SERVER['PHP_SELF'])?>?lang=ru">РУССКИЙ</a></li>
</ul>
Then add an include to the top of each page that uses the webassist server behavior to set a cookie value when the remember url parameter is present.
In the same include you can add code to redirect to the correct language if the cookie is set. The include file will look something like:
if ((isset($_GET['lang']) && $_GET['lang'] != "")) {
setcookie("langpref", "".$_GET['lang']  ."", time()+(60*60*24*30), "/", "", 0);
if (isset($_COOKIE['langpref'])) {
    if (
strpos($_SERVER['PHP_SELF'],$_COOKIE['langpref']) === false) {
header("location: /" . $_COOKIE['langpref'] ."/". basename($_SERVER['PHP_SELF']));
Mags
Works like a dream, thank you Ray!
Mags
Hi Ray, further to the above, our client now wants to send out an email with a list of links to both the English and Russian pages of the site. However, they've discovered that something weird is happening with the URL parameter, but not on all the pages, which is very strange because all pages use the same shared header.php file which contains the cookie. Could you take a look and let me know what might be causing this? Details in PM.
Try this in the include file:
$_COOKIE['langpref'] = $_GET['lang'];
    if (
Mags
That seems to work OK for me, thanks!
astrostrom
This language switch code is very helpful and I am using in my multilingual menu:
<ul>
<li><a href="/de/<?php echo basename($_SERVER['PHP_SELF'])?>">GERMAN</a></li>
<li><a href="/fr/<?php echo basename($_SERVER['PHP_SELF'])?>">FRENCH</a></li>
</ul>
which is O.K. for static pages.
However, when the page is dynamically served such as:
swissart_news.php?article_id=352
The language switch works but the dynamic content is not loaded.
Is it possible to optimize the code to enable this?
I know this is not a specific WA issue but many thanks for any help.
Can you try:
parse_str
($_SERVER['QUERY_STRING'], $vars);
$query = http_build_query($vars);
if (
$query) $query = "?" . $query;
<ul>
<li class="active"><a href="/en/<?php echo basename($_SERVER['PHP_SELF']).$query ?>">ENGLISH</a></li>
<li><a href="/de/<?php echo basename($_SERVER['PHP_SELF']).$query ?>">GERMAN</a></li>
<li><a href="/fr/<?php echo basename($_SERVER['PHP_SELF']).$query ?>">FRENCH</a></li>
</ul>
astrostrom
Works like magic!
Many thanks Ray
