Not working
Thread begun 11/11/2016 2:56 am by J7HNW | Last modified 11/14/2016 9:35 am by Ray Borduin | 1534 views | 3 replies |
J7HNW
Not working
Hi
Dynamic connections does not appear to be working in CC2017
See attached - you cannot select a second remote connection as you cannot select the top left button
It is all blurred
Hope you can help
J
Thank you for bringing this to my attention. I see the same thing.
You can still use it however. If you click the bottom part of the button on the left that is mostly covered by the other buttons it will fix everything and the interface will become usable.
I'll look into getting it to look correct when it opens in a future release.
J7HNW
Thanks Ray
Please can you advise - having run Dataassist pages I have an issue
http://www.mikehow.com/admin/
I can see the products when I click the link
http://www.mikehow.com/admin/products_results.php
However if I click on VIEW or UPDATE I get this error message
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Condition, Available, Price, VAT FROM products WHERE Product_Stock_Number = 1' at line 1
Please can you advise what I have done wrong
John
Jason Byrnes
Looks like you are using a reserved word for the name of a column in your table. The error starts at the column name "Condition", This is on the list of reserved words from the MySQL Documentation.
https://dev.mysql.com/doc/refman/5.5/en/keywords.html
Reserved words should be avoided as column names in your table.
