DW 2017 issue
Thread begun 11/10/2016 6:34 am by Sweens | Last modified 1/03/2017 12:44 pm by Ray Borduin | 4581 views | 9 replies |
Sweens
DW 2017 issue
Hi
Since upgrading to DW 2017 I'm unable to drag a recordset field from the bindings tab into the code in the body of a page, for example when trying to add a parameter to an url.
Is it me, or is this a general problem?
Cheers
Chris
It appears to be a problem. I can still drag and drop into design view, but not code view. Setting the cursor to the correct position in code view and clicking the "insert" button still seems to work.
Sweens
Thanks Ray.
Have to laugh - I've been using DW for years and never noticed/used the Insert button! I will from now on.
Cheers
Chris
Sweens
Hi Ray
I'm continuing to have problems with 2017 and have had to revert to 2015 to keep things going. Now Christmas is out of the way, I'd like to try and get things working properly.
My main issue is with the MySQLi extension - unable to click to add recordset fields to a query.
Does this work for you?
Cheers
Chris
No it doesn't... That is a bug in Dreamweaver that I can't fix since it is an underlying problem with the tree control built into dreamweaver. They may fix it in a future version.. But you can use the querybuilder in MySQLi we added instead. It is a more robust way of building queries.
Sweens
Hi Ray
Thanks. The other issue is javascript errors whenever I open a dynamic page. I've cleared the cache and chnged the workspace layout, as suggested in the forums, but to no avail.
I get:
Whilst executing findDynamicSources in Recordset.htm a Favascript error occurred
The mysqli query builder then doesn't work.
Cheers
Chris
That could be a conflict with another extension or a problem with the page you are working on specifically. Can you send me a copy of the page and I can take a look and see if I can reproduce it.
If not, I'd have to set up a screen sharing session to debug that one.
Sweens
Thanks Ray - it happens on every dynamic page.
Skype in pm
Cheers
Chris
We can chat in Skype and coordinate a meeting from there.
Sweens
pm
