Can I use the same 'products' database table to add a second product for a different eCart object.
Thread begun 11/09/2016 2:46 am by s.joiner74419001 | Last modified 11/11/2016 1:59 pm by Ray Borduin | 1890 views | 3 replies |
s.joiner74419001
I currently have a membership application form on our website that uses eCart for the user to be directed to a PayPal system to pay the fee after completing the form. The 'Add to eCart' behaviour uses the 'products' database table to get the membership data to build the correct transaction.
I am wanting to introduce a second type of membership that will be using a new application form with its own eCart object and my question is can I add this as a second product to the 'products' database table that the previous application uses. My concern is that I assume they will both have to reference there primary key, but when I inspect the code in the 'eCart Add to Cart' behaviour it appears to bind the data by the column name and not the data row.
such as - $ATC_itemID = "".$row_rsProduct['ProductID'] ."";
Hope this makes sense.
Thanks in advance
Yes, you should be able to use the same products table without any problems.
s.joiner74419001
Hi Ray
OK, well then where does it reference the correct ProductID, because I can't see anywhere in the code where it does. That is my concern, because if I add a second product to the table where does it determine which product to use for the cart? In the 'AddToCart' behaviour it uses a recordset thats built around the products table. But there is no variable to determine which row to use. ( see attached screen shot ) Not a problem I imagine when there is only a single row of data in the table.
Im a bit out of my depth here but I just need to be 100% sure before I attempt to build this.
Thanks in advance.
Steve
Is this on a results page or details page?
Once you add a second product, this page will be filtered to display that product. Then it will get the ID from the recordset where the product is displayed. The code is on line 51 where it refers to the ID from the recordset which will be different for each product.
