How to Diagnose "Error in SQL Syntax" on live server
Thread begun 11/08/2016 3:25 am by astrostrom | Last modified 12/02/2016 9:48 am by Ray Borduin | 2042 views | 4 replies |
astrostrom
I have a set of admin pages that works fine locally. But on the live server I get the "Error in SQL Syntax" message. I ran a Test DB connection script and connection worked. I created a new DB user on the server backend and deleted the rsobj.php file and regenerated a new one by making a new recordset.
BTW - I did not find the line "Debug = false;" in the rsobj.php file - so I added it to the file but it did not help.
Checked the SQL in phpMyAdmin - no problem - so it must be a connection error of some kind.
Any idea what do to next?
It should give you better error messages if you change Debug to true. If you give me a url and ftp access I could help debug it.
astrostrom
Thanks, Ray, I will send the server details via PM
You had your connection host server set to: 'localhost
it of course should have just been: localhost
Updating it fixed your page.
astrostrom
Silly me. Many thanks for the help!!
