Email not Sending
Thread began 11/04/2016 6:03 am by Daryl | Last modified 11/08/2016 12:36 am by Ray Borduin | 1571 views | 5 replies |
DarylBeta Tester
Email not Sending
I have created a form to be emailed and have added the UE behaviours.
I have setup a PEARL SMTP connection and have tried troubleshooting by turning on errors and adding the session var dump however the only information displayed after sending is array 0 and the page is not redirected on sending
I'd need FTP access to debug this since all of the code will be on the server.
DarylBeta Tester
Thank you Ray
ftp details in PM
It appears that server doesn't have PEAR installed. I've updated the code so that it tries to send, but now you get a missing pear file error.
DarylBeta Tester
Hi Ray
I was asked to change the path to PEAR from the local to a global option, which I have done (I have put their reply in the private message)
The page now loads but again the email fails and array 0 is shown in the debug code at the bottom of the page.
It appears you were using the "current page submit" trigger. This trigger checks the referrer and compares it to the page name. Since you are using a mod rewrite it doesn't match properly.
I resolved the problem by changing the email trigger to use the button press.
