Update page deleting entire record
Thread began 10/31/2016 11:57 am by tmcbinc99963 | Last modified 11/04/2016 11:29 am by Ray Borduin | 1375 views | 4 replies |
tmcbinc99963
I have an admin page that updates a products/lube relational table by using foreign keys from a products table and a lube table (using the Manage Relational Tables server behavior).
When I attempt to update the product type checkbox list (from grease to engine oils, for example), it updates the product/lube table primary key to a value of 0, resulting in a 'this record has been removed' message.
The Lube and Product foreign keys update correctly.
The site pages are included and can be viewed live (see PM).
It looks like you haven't defined your prodtype table to have an autonumber column. That is preventing the inserts for the new checked lube types.
tmcbinc99963
Locally, auto_increment was added to the prodtype table, and a new search was performed for product number 201. The results still say 'record has been removed', and the record is gone from the prodtype foreign key table (the record is still there in the products table). In addition, the new search won't find any of the first 5 products with primary keys 1-5 for some reason.
When the record is added back in to the prodtype table manually, and a new search is performed for that product, it returns 'no record found'. And, still doesn't find the first five products.
When the Db is replaced with a backup from the remote server, the search works properly, including finding the first 5 products.
You have four INNER JOIN references in your recordset on the results page. That means if there aren't associated records in any of the four associated tables the recordset won't return results.
If you change them to LEFT OUTER JOIN instead then the results page will return results even if the joined tables don't have associated rows. If adding the prodtype manually doesn't fix the problem it means the problem is (also?) with the lubetype, prodsize, or contsize tables.
In your case it was an issue with an old checkbox name reference in the manage relational table server behavior for the prodsize table.
It appears you still have an issue with the autonumber column not being set for either the prodtype or prodsize table.
tmcbinc99963
The issue seemed to be adding auto_increment to every associated table. I had corrected every table except the products table. It's working as expected now.
