SA Show Region - is this a bug?
Thread begun 9/05/2009 7:59 am by Paul | Last modified 9/08/2009 11:21 am by Eric Mittman | 2309 views | 2 replies |
PaulBeta Tester
I've noticed that the name used in the code generated by this feature does not show correctly when looking at code view page.
For example, take the rule <?php if(!WA_Auth_RulePasses("Logged in to clients")){ // Begin Show Region ?>
The name of this item in the server behaviours list is "Not Logged in to clients".
Consequently, if used, one could be forgiven for thinking that a different rule had been used if one just looked at the rule name in code view.
The other bug is that if a rule is selected, say Logged in to clients, by clicking on it in the Server Behaviour box, then exit when done, the quote marks around the show region name dissappear, showing instead (&quot;Logged in to cp_clients&quot;). off course the code is now corrupt and will not function.
Are these bugs?
Paul
anonymous
Paul,
I don't think the first one is a bug - as the exclamation point in PHP denotes negative, so to me, that codes reads perfectly logical for the the item you are describing.
The second thing, though, looks really strange.
Regards,
Brian
Where is it that you are seeing this problem with the quotes? The code on the page should look like this:
this is something
<?php } // End Show Region ?>
In design view you should see the content of your show region with a thin box around it that has a show region marker associated with it.
When I have my show region on the page I can edit it from the server behaviors tab of the application panel and it will reflect whatever rule I change it to without encoding any quotes. Please let us know where you are experiencing this and exactly how you got it this was so that we can check this out further.
