Show if conditional region syntax
Thread begun 10/27/2016 4:17 am by Nixtev | Last modified 10/27/2016 4:32 pm by Ray Borduin | 1635 views | 4 replies |
Nixtev
I'm busy converting a site with a lot of coding generated by ADDT and other PHP/MySQL extensions over to MySQLi and thought I'd better check before I go any further that what I've got is correct, or if it will cause me problems further down the line.
The code I had was
// Show IF Conditional TopMenu
if (@$row_Rs_siteinfomnu['site_menu'] >= "2"
AND
@$row_Rs_siteinfomnu['site_menu'] <= "4") {
so does that simply become
if ($Rs_siteinfomnu->getColumnVal("site_menu") >= "2"
AND
$Rs_siteinfomnu->getColumnVal("site_menu") <= "4") {
or do I need to do anything else?
I also have this one that I need to convert as well but not yet sure if I'm heading in the right direction!
<?php // Hide if RS Field is Null
$field = $row_Rs_dog['photo1_copyr'];
if(strlen($field) > 0){
which I've got as far as changing to
$field = $Rs_dog->getColumnVal("photo1_copyr");
but really not sure if that's going to be the right way to do it or not.
Thanks.
That all looks correct to me.
Nixtev
Oh that's great thanks :)
I had hoped that these options would be available for the MySQLi extension by now as coding isn't my strongest point but needs must!
I've also got a nested repeat region that I'm a bit stuck with so while I think I've got the rest of it done, I don't know how to get this bit working so how would I go about this please as so far I just have a repeat region inside an repeat region?
I'm trying to get
while(!$detail2dogs_i->atEnd()) {
<li><a href="dogpge.php?dog=<?php echo($detail2dogs_i->getColumnVal("dog_ID")); ?>"><?php echo($detail2dogs_i->getColumnVal("dog_titlepre")); ?> <?php echo($detail2dogs_i->getColumnVal("dog_showname")); ?></a></li>
$detail2dogs_i->moveNext();
$detail2dogs_i->moveFirst(); //return RS to first record
to do what
if ($totalRows_Rs_dog_sec>0) {
$nested_query_detail2dogs = str_replace("123456789", $row_Rs_dog_sec['dogsection_ID'], $query_detail2dogs);
mysql_select_db($database_updates);
$detail2dogs = mysql_query($nested_query_detail2dogs, $updates) or die(mysql_error());
$row_detail2dogs = mysql_fetch_assoc($detail2dogs);
$totalRows_detail2dogs = mysql_num_rows($detail2dogs);
$nested_sw = false;
if (isset($row_detail2dogs) && is_array($row_detail2dogs)) {
do { //Nested repeat
<li><a href="dogpge.php?dog=<?php echo $row_detail2dogs['dog_ID']; ?>"><?php echo $row_detail2dogs['dog_titlepre']; ?> <?php echo $row_detail2dogs['dog_showname']; ?></a></li>
} while ($row_detail2dogs = mysql_fetch_assoc($detail2dogs)); //Nested move next
does. I need to filter the nested region to only show results relevant to it's parent value but am lost on how to do that.
The full block of old code is
(Old code)
mysql_select_db($database_updates, $updates);
$query_Rs_dog_sec = "SELECT dogsection_ID, dogsection_name, dogsection_display, dogsection_displayorder FROM dogsection WHERE dogsection_display = 'Y' ORDER BY dogsection_displayorder ASC";
$Rs_dog_sec = mysql_query($query_Rs_dog_sec, $updates) or die(mysql_error());
$row_Rs_dog_sec = mysql_fetch_assoc($Rs_dog_sec);
$totalRows_Rs_dog_sec = mysql_num_rows($Rs_dog_sec);
$query_detail2dogs = "SELECT dogs.dog_ID, dogs.dog_showname, dogs.dog_titlepre, dogs.dog_titleaf, dogs.dog_sex, dogs.dog_breedID, dogs.dog_sectionID, dogs.dog_owner, dogs.dog_breeder, dogs.dog_display, dogs.dog_displayorder, dogs.dog_sitedog_ID FROM dogs WHERE dogs.dog_sectionID=123456789 AND dogs.dog_owner='Y' AND dogs.dog_display = 'Y' AND dogs.dog_sitedog_ID = 1 ORDER BY dogs.dog_displayorder ASC";
$detail2dogs = mysql_query($query_detail2dogs, $updates) or die(mysql_error());
<?php do { ?>
<!-- open li -->
<li>
<a href="dogsec.php?s=<?php echo $row_Rs_dog_sec['dogsection_ID']; ?>"><?php echo $row_Rs_dog_sec['dogsection_name']; ?></a>
// Show IF Conditional TopMenuDogSecs
if (@$row_Rs_siteinfomenu['site_menu'] >= "2") {
<!-- open ul -->
<ul>
$nested_sw = false;
<!-- close ul -->
</ul>
<?php }
// endif Conditional TopMenuDogSecs
<!-- close li -->
</li>
<?php } while ($row_Rs_dog_sec = mysql_fetch_assoc($Rs_dog_sec)); ?>
so I've now got
(New code)
$Rs_dog_sec_i = new WA_MySQLi_RS("Rs_dog_sec_i",$updates_i,0);
$Rs_dog_sec_i->setQuery("SELECT dogsection_ID, dogsection_name, dogsection_display, dogsection_displayorder FROM dogsection WHERE dogsection_display = 'Y' ORDER BY dogsection_displayorder ASC");
$Rs_dog_sec_i->execute();
$detail2dogs_i = new WA_MySQLi_RS("detail2dogs_i",$updates_i,0);
$detail2dogs_i->setQuery("SELECT dogs.dog_ID, dogs.dog_showname, dogs.dog_titlepre, dogs.dog_titleaf, dogs.dog_sex, dogs.dog_breedID, dogs.dog_sectionID, dogs.dog_owner, dogs.dog_breeder, dogs.dog_display, dogs.dog_displayorder, dogs.dog_sitedog_ID FROM dogs WHERE dogs.dog_sectionID=123456789 AND dogs.dog_owner='Y' AND dogs.dog_display = 'Y' AND dogs.dog_sitedog_ID = 1 ORDER BY dogs.dog_displayorder ASC");
$detail2dogs_i->execute();
while(!$Rs_dog_sec_i->atEnd()) {
<!-- open li -->
<li><a href="dogsec.php?s=<?php echo($Rs_dog_sec_i->getColumnVal("dogsection_ID")); ?>"><?php echo($Rs_dog_sec_i->getColumnVal("dogsection_name")); ?></a>
if ($Rs_siteinfomenu_i->getColumnVal("site_menu") >= "2") {
<!-- open ul -->
<ul>
<!-- close ul -->
</ul>
<?php }
<!-- close li -->
</li>
$Rs_dog_sec_i->moveNext();
$Rs_dog_sec_i->moveFirst(); //return RS to first record
Thanks.
You have to move the recordset for the nested repeat into the while loop where you want it nested. That way it is recreated for each row and can be filtered based on the current row of the parent recordset.
Nixtev
Thanks, I'm still trying to get my head around all the different looking code and that the "while" bit appears to have moved from the bottom of the block to the top now so I don't know how much of that old code block I can just borrow and change the obvious bits or if it all needs re-doing.
