How do I get a CAPTCHA to work in the Power Store?
Thread began 10/26/2016 12:58 pm by john42771 | Last modified 10/31/2016 10:32 am by Ray Borduin | 2658 views | 9 replies |
john42771
The page with the form is checkout7.php and it is embedded in checkout.php.
Still not working after following tutorials and various tips on this forum.
Can you please help me?
http://www.lovetakeslearning.com/store/checkout.php
The validation would take place on the confirm7_cart.php page. I imagine that is where the problem is, but you didn't attach that page for me to look at.
What exactly isn't working? Is it allowing any captcha value to pass? or never accepting the captcha?
john42771
Thanks for looking at this. I did not realize that I needed to do anything on this page. Here's the page you mentioned.
Thanks again for helping me sort this out,
John
You need to open up the Server Validations server behavior and add the Like Entry validation to compare the entered value to the correct captcha value.
To add the code manually, you can add this after line 33 on confirm7_cart.php.
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code_1"])?$_POST["Security_Code_1"]:"")) . "",((isset($_SESSION["captcha_Security_Code_1"]))?strtolower($_SESSION["captcha_Security_Code_1"]):"") . "",true,10);
john42771
Ray,
Thanks so much for the replies. I have done the above with no different results.
(When I click continue, a lightbox begins to open... Open... Nope. CLOSE. I remain on the checkout.php page. I can get no further.
Please let me know as soon as you're able. Your help is very appreciated.
John
PS
I noticed that the submitting form posts Security_Code_1, not Security_Code as in your manual code example, so I changed it... No change to results. I have attached the latest files. Please be so kind as to inspect.
The code for the CAPTCHA looks correct to me. Can I get FTP access to the server to debug it?
john42771
Your requested info is in the private area.
Thanks Ray.
There were two issues.
1) You had renamed your checkout button from "CheckoutWizard_submit" to "submit"
2) You had the form variable referenced as: $_POST["Security_Code1"] instead of: $_POST["Security_Code_1"]
I corrected those two things and it appears to be working properly now.
john42771
Ray,
Thanks for getting to this in such a timely manner. I greatly appreciate it.
See PayPal for a little tip!
John
Thanks John. I appreciate it, and I'm glad it is working for you now.
