shipping calculations are not correctly calculated
Thread begun 10/23/2016 12:07 pm by Christopher West | Last modified 10/24/2016 7:21 pm by Ray Borduin | 5265 views | 9 replies |
Hi, I have a shipping system that calculates basket based on weight X size X ChargeDelivery(ChargeDelivery is a checkbox on products table).
(Also please see screenshots)
In my eCart General tab:
Number format: 10,000.00
In my eCart Columns tab:
ChargeDelivery = (this is a number)
Width = (this is a number)
Height = (this is a number)
Depth = (this is a number)
In my Calculations tab:
TotalWeight = [Weight] * [Quantity] * [ChargeDelivery]
TotalSize = ([Width] * [Height] * [Depth]) * [Quantity] * [ChargeDelivery]
QUESTION 1: is the above how it should be set up for the type of calculation I want?
My PHP code:
$rsShippingZone
= new WA_MySQLi_RS("rsShippingZone",$ecartdb,1);
$rsShippingZone->setQuery("SELECT * FROM shippingzones WHERE ShippingZoneCode = ? AND ShippingZoneEnabled = 1");
$rsShippingZone->bindParam("s""".(isset($_SESSION['ZonePostCode'])?$_SESSION['ZonePostCode']:"")  ."""-1"); //colname
$rsShippingZone->execute();
$rsDeliveryCost
= new WA_MySQLi_RS("rsDeliveryCost",$ecartdb,1);
$rsDeliveryCost->setQuery("SELECT * FROM shippingcosts WHERE ShippingCostZone = ? AND ShippingCostEnabled = 1 AND ShippingCostWeightTo >= ? AND ShippingCostSize >= ? ORDER BY ShippingCostValue ASC");
$rsDeliveryCost->bindParam("s""".$rsShippingZone->getColumnVal("ShippingZone")  ."""-1"); //colname
$rsDeliveryCost->bindParam("s""".$eCart->TotalColumn("TotalWeight")  ."""-1"); //colname2
$rsDeliveryCost->bindParam("s""".$eCart->TotalColumn("TotalSize")  ."""-1"); //colname3
$rsDeliveryCost->execute();?>
QUESTION 2 : in the above PHP code, is that how I should be defining the SQL query?
On many test of the basket, the delivery cost ends up being FREE (so obviously its unable to select a SQL query) or the delivery cost ends up being £2.5 (max size 900cm3) Even though the basket totalsize is way over 900cm3).
Can you see any obvious mistakes in my logic?
Take a look at my test screenshots and compare to the shipping rules screenshot. if you look at test3.png its showing £12.99 for delivery cost by the total size is 13,585cm3 and totalweight is 3kg (so I cant figure out why its selecting £12.99 if you compare the sipping rules screenshot.
the code that displays FREE is:
<?php if ($eCart->GetShipping() > 0) { ?>
           <strong>£<?php echo $eCart->GetShipping(); ?></strong>
           <?php } else { ?>
           <strong>Free</strong>
<?php ?>
***UPDATE***
I think it maybe the sql query as I done a test outputting some sessions variables based on the 2 recordsets above. and it only displays a value from my rsShippingZone recordset. On the test page nothing is displayed from my sessions I used to grab some bindings from the rsDeliveryCost. Which would suggest that this recordset sql query is returning 0 results. Not sure why though?
I edited the recordset to the following and I am getting better results....but does the logic make sense as I remember Ray you suggested using >= and ASC for order by.
$rsDeliveryCost
$rsDeliveryCost->setQuery("SELECT * FROM shippingcosts WHERE ShippingCostZone = ? AND ShippingCostWeightTo <= ? AND ShippingCostSize <= ? ORDER BY ShippingCostValue DESC");
Chris
It looks like the data types for those columns are set to varchar instead of int or double. That would make it difficult to do number type of comparisons.
I think >= is the one that makes the most sense. I would think you would be saving the maximum weight and maximum volume for a given shipping option. That would mean you would want the value in the cart to be less than that maximum for the shipping to be applicable. Then you would sort by the cost ASC because you would want the lowest cost that was applicable for that size shipment.
Hi ok the wrong data type makes sense. I think in my database for some reason I had it as varchar (I think because when originally I had it in my CSV file the numbers were getting rounded up) So in my database should I set them to either Int, Double or Float? In the eCart object general, columns and calculations tab which drop down should I use (currently number).
Chris
Number is correct for the cart column type. Int appears appropriate for the database column since you have only whole numbers.
Before you replied I already change it. Could I just confirm (just in case there would be potential issues) the following:
(1) in eCart object instead of Number I used Integer (would this be a problem, what is the difference between those 2 options)
(2) in my database I ended up using Float for weight fields and Float for Sizes (because sizes will have a 2 decimal point value).
For weight even though I used Float would this cause any issues? Yes the delivery companies provide whole numbers. But also the shopping basket could have a weight of a 2 decimal value so I figured just to keep them as Floats. Any downsides?
Chris
Floats is fine. The only difference is weather it saves decimals or not.
Ok cool, but I'm the eCart Object what's the difference between the option 'Number' and 'Integer' (or was your reply referring to that and not my other database question) :)
Chris
Yes same thing.... allows decimals or not.
Ah so if I need decimal point numbers I need to use Number (not Integer) in the eCart object?
Chris
That is correct
