eCart Store Summary not working how expected
Thread begun 10/23/2016 11:49 am by Christopher West | Last modified 11/28/2016 11:15 am by Ray Borduin | 3847 views | 5 replies |
Hi, as the question topic suggests, I am having problems.
I'm using the server behavior to import data from a CSV file. I decided to use this method so that the client can edit product details and add new ones then import the file into the database. I feel that somewhere my logic is wrong. It works with adding new product entries, but doesn't update any existing products that have been edited in the csv file.
if you were to look at the core code below, is there an obvious reason or where I have gone wrong? (NOTE: I removed some of the columns to keep the code small for this topic (but it doesnt alter the functionality).
NOTE: ProductSKU is the only field that will never change and is unique, hence why I used it as a filter.
if (($handle fopen("../files/libra-products.csv""r")) !== FALSE) {
fgetcsv($handle);
   while ((
$data fgetcsv($handle1000",")) !== FALSE) {
$num count($data);
        for (
$c=0$c $num$c++) {
$col[$c] = $data[$c];
$col1 $col[0];
$col2 $col[1];
$col3 $col[2];
$col4 $col[3];
$col5 $col[4];
$col6 $col[5];
$col7 $col[6];
 if (
$ConditionalQuery = new WA_MySQLi_Query($ecartdb);
$ConditionalQuery->Action "conditional";
$ConditionalQuery->Table "products";
$ConditionalQuery->saveInSession("ProductSKU");
$ConditionalGoTo "";
  if (
function_exists("rel2abs")) $ConditionalGoTo $ConditionalGoTo?rel2abs($ConditionalGoTo,dirname(__FILE__)):"";
$ConditionalQuery->redirect($ConditionalGoTo);
  if (isset(
$_SESSION[$ConditionalQuery->SaveAs])) $ConditionalQuery->addFilter("ProductSKU""=""s"$_SESSION[$ConditionalQuery->SaveAs]);
$ConditionalQuery->bindColumn("ProductEnabled""s"$col1"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductSKU""s"$col2"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductName""s"$col3"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductBrand""s"$col4"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductPrice""s"$col5"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductRRP""s"$col6"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductQuantity""s"$col7"WA_DEFAULT");
$ConditionalQuery->execute();
Chris
It seems like this line:
if (isset($_SESSION[$ConditionalQuery->SaveAs])) $ConditionalQuery->addFilter("ProductSKU", "=", "s", $_SESSION[$ConditionalQuery->SaveAs]);
should be referring to the sku from your csv and not a session variable.
ah ok, can you give an example of how I should change that line please?
Chris
$ConditionalQuery->addFilter("ProductSKU", "=", "s", $col2);
Hi. it seems to work (database is update after initial tests) but i do get lots of these errors:
Notice: Undefined offset: 28 in C:\xampp\htdocs\armadillo\admin\libra-product-import.php on line 65
Notice: Undefined offset: 29 in C:\xampp\htdocs\armadillo\admin\libra-product-import.php on line 66
my current code is this:
fgetcsv($handle);
   while ((
$num count($data);
        for (
$c=0$c $num$c++) {
$col1 $col[0];
$col2 $col[1];
$col3 $col[2];
$col4 $col[3];
$col5 $col[4];
$col6 $col[5];
$col7 $col[6];
$col8 $col[7];
$col9 $col[8];
$col10 $col[9];
$col11 $col[10];
$col12 $col[11];
$col13 $col[12];
$col14 $col[13];
$col15 $col[14];
$col16 $col[15];
$col17 $col[16];
$col18 $col[17];
$col19 $col[18];
$col20 $col[19];
$col21 $col[20];
$col22 $col[21];
$col23 $col[22];
$col24 $col[23];
$col25 $col[24];
$col26 $col[25];
$col27 $col[26];
$col28 $col[27];
$col29 $col[28];
$col30 $col[29];
 if (
  if (
  if (
$ConditionalQuery->addFilter("ProductSKU""=""s"$col2));
$ConditionalQuery->bindColumn("ProductChargeDelivery""s"$col8"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductCollectionOnly""s"$col9"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductCallDelivery""s"$col10"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductSale""s"$col11"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductNewArrival""s"$col12"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductBestSeller""s"$col13"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductInStoreNow""s"$col14"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductWeight""s"$col15"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductHeight""s"$col16"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductWidth""s"$col17"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDepth""s"$col18"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDeliveryWeight""s"$col19"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDeliveryHeight""s"$col20"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDeliveryWidth""s"$col21"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDeliveryDepth""s"$col22"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDescription""s"$col23"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductKeywords""s"$col24"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductMetaTitle""s"$col25"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductMetaDescription""s"$col26"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDiscontinued""s"$col27"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductOutStock""s"$col28"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductCreateDate""s"$col29"WA_DEFAULT");
$ConditionalQuery->bindColumn("ProductDateEdit""s"$col30"WA_DEFAULT");
This implies that there aren't 30 columns in the imported csv file, so it is complaining that you are referring to two columns that don't exist.
