checkbox has no properties dialog keeps appearing when building the dataassist pages
trying to run data assist page generation wizards but keep getting that attached message appearing (1 for each checkbox )
am ideas as to the possible cause
What form design are you using?
I wasn't able to reproduce the problem, but I only found reference to that variable in a few places, so I might have been able to fix it. I've attached a file you can try replacing your version in the users configuration for dreamweaver location:
/Adobe/Dreamweaver CC 2015/en_US/Configuration/Shared/WebAssist/Services/fb_shared_functions.php
Replace it with Dreamweaver closed and then clear the cache.dat file in the Configuration folder and then try again. If that doesn't work I'll need to set up a screen sharing session to debug and fix this with you directly.
that appears to have worked
