mysqli update
Thread begun 10/19/2016 4:43 am by Jamie | Last modified 10/20/2016 6:38 pm by Ray Borduin | 2360 views | 4 replies |
Jamie
mysqli update
Hi Ray
Am trying to get a msqli update to work on a couple of pages. One is a simple dingle update (user_message.php) the other is to do a multiple update (user_messages.php) which I dont know how to do (or convert from a mysql version) both of which pages are attached.
Both pages are trying to use the checkbox 'Message Read' to update db the column MessageRead in the db messages - just one is a single update, the other is a multiple
Thanks in advance
Jamie
The single update is updating based on the $_GET variable, but you aren't passing it through the form post. The easy solution is to just remove the form action and the url parameters will be automatically forwarded.
You can convert the multiple update by:
1) rename the checkbox to: MessageRead[]
2) set the value of the checkbox to the unique ID for the table
3) apply the update server behavior. Set the ID to update to: <?php echo($loopID); ?>
4) manually wrap the update code in a for loop like:
if (isset($_POST['Update'])) {
$updateIDs = $_POST['MessageRead'];
for ($x=0; $x<sizeof($updateIDs); $x++) {
$loopID = $updateIDs[$x];
/// update code here ///
Jamie
thanks for all that.
I had tried the single without the form action earlier and it didnt work - just redirected to itself but didnt update the db - just tried it again and still doing the same.
(Will take a look at the multiple tomorrow and see how i get on)
Jamie
OK, have tried the multiple update but its not working and the checkboxes are no longer visible...
have also been trying to get the single to work but it doesnt nor does it redirect to the page specififed in the update server behaviour
both files attached so you can see where I have gone wrong?
thanks mate
We figured this out in a premier support ticket.
You had a few issues:
1) You still had form validation from another page on the top preventing any form submits from going through
2) You had wrapped the checkbox instead of the update server behavior with the for loop I suggested
We corrected those two issues and the page is working now.
