Calculation inserted in to a form field based on the user entered value of two other fields...how to add decimal points?
Thread begun 10/18/2016 2:03 pm by Nathon Jones Web Design | Last modified 10/19/2016 12:04 am by Ray Borduin | 918 views | 2 replies |
I'm so close with this. Can anyone help?
Here's the basic form:
<form>
<input type="text" class="form-control" id="PFexCHARGE" name="PFexCHARGE" value="0.00">
<input type="text" class="form-control" id="PFexV2" name="PFexV2" value="0.00">
<input type="text" class="form-control" id="PFexPX" name="PFexPX" value="">
</form>
Here's the script:
<script>
$(':input').on('change keyup check',function () { // run anytime the value changes
var firstValueComplex = parseFloat($('#PFexCHARGE').val()) || 0; // get value of field
var secondValueComplex = parseFloat($('#PFexV2').val()); // convert it to a float
$('#PFexPX').val(firstValueComplex + secondValueComplex)
function resizeCrossDomainIframe(id, other_domain) {
var iframe = document.getElementById(id);
window.addEventListener('message', function(event) {
if (event.origin !== other_domain) return;
if (isNaN(event.data)) return;
var height = parseInt(event.data) + 500;
iframe.height = height + "px";
}, false);
</script>
This works nicely however I need to ensure that the final field includes two decimal points as these are monetary values and it needs to view as such.
Thanks for any help offered.
Regards
NJ
Use:
$('#PFexPX').val((firstValueComplex + secondValueComplex).toFixed(2))
You da man! :)
Thank you Ray.
Regards
NJ
