session value space added
Thread begun 10/17/2016 7:28 am by Jamie | Last modified 10/17/2016 12:38 pm by Ray Borduin | 1637 views | 4 replies |
Jamie
Hi Ray
I am creating a session
<?php echo($_GET['UserID']); ?>
based on the url such as this:
/admin_cms/customer_update.php?UserID=15
When I then use the session on another page to go back to the page its set on using something like
customer_update.php?UserID=<?php echo $_SESSION['UserID']; ?>
, for some reason its adding a space in front of the value so it then becomes
/admin_cms/customer_update.php?UserID= 15
what am I doing wrong for that to be happening?
Cheers
J
What is the code that sets the session? Maybe the problem is there? Maybe there is a space in front of it.
Jamie
It's
@session_start();
if ("" == "") {
$_SESSION["UserID"] = "".($_GET['UserID']) ."";
The space has to be added somewhere. Are you sure it isn't in the original url? If I could see the actual code on the pages I could probably find it.
There is a space somewhere... either in the url, where the session is set, or where it is written.
Jamie
thanks Ray. Had a hunt around and found a couple of instances (I had tried a few times to add a session) of th session one of which had the space in it. So have deleted all but the one on the main page.
