Radio Buttons Not Populating
Thread begun 10/11/2016 8:33 am by tn228553 | Last modified 10/12/2016 11:02 am by Ray Borduin | 1723 views | 4 replies |
tn228553
Attached is a default userupdate.php from building out a Security Assist login page. Everything is working great EXCEPT for the radio buttons for the Accepted value. It is not bringing forward the value and marking either of the radio buttons as "checked" even though it is saved in the database?
Is there a bug in the code that was generated?
It looks like there is an issue with the code. It isn't looking at the database column for the previously selected value. Line 155 should be:
<input type="radio" name="User_Update_group_4_Accepted" id="User_Update_group_4_Accepted__1" value="this" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_4_Accepted"):"".$row_SecurityAssistMSFields["Accepted"]  .""),"this"))) {echo "checked=\"checked\"";} ?> tabindex="4" title="Please enter a value.">
and line 158 should be:
<input type="radio" name="User_Update_group_4_Accepted" id="User_Update_group_4_Accepted__2" value="that" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_4_Accepted"):"".$row_SecurityAssistMSFields["Accepted"]  .""),"that"))) {echo "checked=\"checked\"";} ?> tabindex="5">
tn228553
Close
Looks like there were a few typos above? I updated the code until dreamweaver quit throwing an error. Here is what I have now...
Unfortunately, after I save the value it still does not populate the correct radio field. The both stay blank even though it saves to the database. It's almost like the $row_SecurityAssistMSFields["Accepted"] value is not being called/stored from the database when the page reloads?
<label class="radioSublabel_Narrow" for="User_Update_group_4_Accepted__1"> this&nbsp;
</label>
<label class="radioSublabel_Narrow" for="User_Update_group_4_Accepted__2"> that&nbsp;
</label>
Does the database field have the literal value "this" or "that" in it?
tn228553
Fixed
duh, nope. LOL, error on my part. Thanks for the help, looks great!
