Delete record auto after certain time
Thread began 10/05/2016 3:12 am by Kumel | Last modified 10/05/2016 11:05 am by Ray Borduin | 602 views | 1 replies |
Kumel
i have a table where normal records are added.
Ie: PhoneNumber, OTP (6 digit numbers), TimeAdded (format : 2016-10-03 16:44:48)
This generally works as OTP which is sent to users mobile.
When records are entered i want these records (row) to delete automatically after 1 hour using 'TimeAdded'.
How can this be achieved ?
It might be easiest to just do this on the top of the insert page or a page that displays the records.
The other option would be to create a separate page to do the deletes and set up a cron jon on the server. The former would be preferable.
It is easier to manage and would be less prone to error. If you had a cron that ran every hour and deleted any records over an hour old... then hypothetically a record could exist for an hour and 59 minutes before being actually deleted.
If the delete happened on the top of the page that displayed or used the records then the page would always be up to date by the time it was displayed even though records could remain for much longer when the page isn't accessed.
