Update page not reflecting db values for select menus or checkboxes
Thread begun 9/28/2016 3:31 pm by art226587 | Last modified 9/30/2016 2:12 pm by Ray Borduin | 3534 views | 7 replies |
art226587
Hi, I used the DA Pages wizard to create insert, results, update, detail and search pages for a site. All other pages are working correctly except the update page, which populates the text and textarea fields, but doesn't show correct values for checkboxes or select menus.
My text input fields look like this:
<input id="due_date" name="due_date" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("update","due_date"):"".$row_WADAprs_2016["due_date"]."")); ?>" class="formTextfield_Medium" tabindex="2">
My checkboxes like this:
<input type="checkbox" name="comp_needed" id="comp_needed" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("update","comp_needed"):"".$row_WADAprs_2016["comp_needed"].""),"1"))) {echo "checked=\"checked\"";} ?>
I didn't have all of the select menu options when I created the pages, but went back afterward and added them all to my insert and update pages. I realize that this might be an issue, but I'm a novice and haven't the slightest idea where to begin.
Thanks in advance for your help!
Please attach a copy of the page and I can take a look.
Just to confirm: the issue is that the update page doesn't have the correct values selected for checkboxes or select lists but you are sure they are correctly inserted on the insert page. Is that correct?
art226587
Hi Ray, That's correct. See my UPDATE post below where I resolved the checkboxes. update page attached. Thanks!
art226587
UPDATE: I figured out why my checkboxes weren't populating correctly. I had field the values set to "1" instead of "yes" which is what's in the db. Those are working fine. Now I just need to figure out how to make it select the correct values for the select menus. Any thoughts?
Your select lists don't have the selected value code in them at all.
Highlight your select lists and use the lightning bolt to set the selected value. The value should be set to something like:
<?php echo((isset($_GET["invalid"])?ValidatedField("update","rep"):"".$row_WADAprs_2016["rep"]."")); ?>
art226587
Thanks, that was it! I saw that lightning bolt and thought about clicking it, but opted to wait. Everything is selecting the correct options.
Now I have another semi-related question. There are currently three file upload fields on the insert form. Right now I'm just displaying as download links on the update page. I was hoping to display a file upload field if there is no existing file. Is there an easy way to do this? You can see how these fields are set up in the file I sent you.
Thanks again for your help, Ray!
You could use an IF statement to alternatively show the file upload field or link. It might look something like:
if ($row_WADAprs_2016["fileField"]) {
link here
} else {
upload field here
art226587
Thanks, Ray. That worked like a charm.
