checkout button on quick cart and display cart
Thread begun 9/19/2016 4:34 pm by David | Last modified 9/20/2016 8:48 pm by Ray Borduin | 3859 views | 6 replies |
David
I have a checkout button on my quick cart on my purchase page and a separate page for my view cart. I used the wizard to do my checkout via paypal on the page where the quick cart is. This worked fine. The button on the view cart (for checkout) doesn't work. I did change the code on my view cart to read:
//WA eCart Redirect Check Out
if (isset($_POST["wyomingcart_Checkout"]) || isset($_POST["wyomingcart_Checkout_x"])) {
$Redirect_redirStr="checkout.php";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$wyomingcart->redirStr = $Redirect_redirStr;
$wyomingcart->cartAction = "Checkout";
Still doesn't work. Also mirrored the button code from the quick cart to the view cart, no help. Yes these are all before the doctype tag.
What am I missing?
Dave
I'd have to see the whole page to see for sure.
Possibly the card redirect code chunk is missing or too high on the page? If you attach the full page I could say for sure.
David
Ray,
Both pages sent as attachments. Registration checkout button works. The Display checkout button does not. The other functions work fine.
Dave
This code chunk is missing from the cart display page"
// WA eCart Redirect
if ($wyomingcart->redirStr != "")     {
  if (
function_exists("rel2abs")) $wyomingcart->redirStr rel2abs($wyomingcart->redirStr,dirname(__FILE__));
header("Location: ".$wyomingcart->redirStr);
  die();
It should appear just above the doctype tag below all of the other php code.
David
Ray,
Thanks. Now it says:
Warning: Cannot modify header information - headers already sent by (output started at /home/montan37/public_html/wyoming.usawest.net/onlinecartdisplay.php:9) in /home/montan37/public_html/wyoming.usawest.net/onlinecartdisplay.php on line 179
The inserted code begins on line 175
You have a blank line of code at line 8. You can't have blank lines of code in your php or it can cause errors like these. Just delete that blank space and the error should go away.
David
Ray,
Wow, that worked. I would have not caught that one! Thanks for your help.
Dave
