discount on shipping with coupon
Thread begun 9/06/2016 1:24 pm by Christopher West | Last modified 9/11/2016 7:13 pm by Ray Borduin | 4111 views | 7 replies |
hi using the ecart object I am trying to figure out how to create a coupon discount condition that would either give a flat rate or percentage discount to shipping (I have already set up other coupons that give discounts based on items in the cart. but the only options for shipping discounts are UPS, FedEx, US Postal Server, Australia Post and DHL....
I am not using any of these delivery services as I am using my own. And I have set up the delivery costs in ecart already.
Would I have to do this hand coded on my page or is there anyway to add in a coupon calculation for shipping discounts within the ecart object?
Chris
I'd probably do it manually by saving the coupon discount in the session after calculating it based on the total shipping amount and just use that session variable as the discount.
So are you saying, not to use ecart object, but instead use the ecart bindings that are on offer for the one that stores shipping amount and then use my coupon session to subtract that amount from the ecart shipping session? (and do all this on my php page rather than the ecart object?
I'm saying calculate the discount outside of eCart and save it in the session and then use the ecart rule to subtract the discount amount stored in the session.
Hi, would I still be able to show the discount as shipping? so on my basket page shipping will display (for example) £0.00 ?
If you want to do that then just add it as another shipping rule instead of a discount with the session variable value * -1
Hi Ray, with the last part that you wrote, I didn't quite understand the code : * -1 ?
Perhaps I am over-complicating. Looking at a fresh perspective, what do you think of this approach, this is a break down of what I need/done
(1) my discount system comprises of discounts (pounds/percentages for products, sale category or delivery) (done)
(2) the discount conditions for products or sale category would be placed in the discounts tab in the eCart Object. (done)
(3) in the shipping tab of the eCart object, I only have one rule (if session exists then flat rate on the session). (done)
(4) the basket page includes a form for customer to add a coupon code and pressing on the Apply button creates that session (done)
(5) if the coupon relates to either product or sale category then the discount shows on the basket page. (works)
(6) if the coupon relates to delivery then that session will be passed onto my delivery php file. (works)
(7) at checkout on the address page on submit it redirects to my delivery php file (before going to payment page) (works)
(8) on the delivery php file, I am looking up delivery cost in a filtered recordset (works)
(9) I have an IF statement if the customer chooses "store collection" then the delivery session = 0 (works)
(10) if the customer selected "standard delivery" on checkout then the session is based on the filtered recordset. (works)
(11) I need to write an if statement (based on the below conditions) if TRUE then then delivery session = the result on the IF statement (I need to write)
DELIVERY POUND DISCOUNT
If Session variable exists: CouponDiscount
If Session variable CouponType == 2
IF Session variable CouponGroup == 3
If today is after $_SESSION['CouponValidFrom']
If today is before $_SESSION['CouponValidTo']
{create the calculation for the current delivery cost - the coupon session value}
DELIVERY PERCENTAGE DISCOUNT
If Session variable CouponType == 1
based on the cart subtotal
{create the caculation for the current delivery cost - the coupon session value as a percentage}
To me the above seems clear in my head as an approach as then I can add extra code to show the customer that delivery is discounted etc.
I just need to work out the calculations using the above conditions. I have coded this and wondered if it makes sense this way:
// Percentage
if (((isset($_SESSION['CouponDiscount']))
&& ((isset(
$_SESSION['CouponType'])?$_SESSION['CouponType']:"") == "1")
&& ((isset(
$_SESSION['CouponGroup'])?$_SESSION['CouponGroup']:"") == "3")
time() >= strtotime("".$_SESSION['CouponValidFrom']  .""))
time() <= strtotime("".$_SESSION['CouponValidTo']  ."")))) {
$_SESSION["EstimatedDeliveryCost"] = $_SESSION["EstimatedDeliveryCost"] - (($_SESSION["EstimatedDeliveryCost"] * $_SESSION['CouponDiscount']));
// Flat Rate
&& ((isset(
$_SESSION['CouponType'])?$_SESSION['CouponType']:"") == "2")
&& ((isset(
$_SESSION["EstimatedDeliveryCost"] = ($_SESSION["EstimatedDeliveryCost"] - $_SESSION['CouponDiscount']);
I don't see an issue with this approach. I could help you figure this out in a premier support ticket.
