bug found in eCart_PHP recarding discount rules
Thread begun 9/04/2016 4:35 pm by Christopher West | Last modified 9/08/2016 10:41 am by Ray Borduin | 2229 views | 4 replies |
Hi there, I just finished creating some discount rules in the eCart object. and on uploading to localhost I have the following error:
Parse error: syntax error, unexpected '' (T_ENCAPSED_AND_WHITESPACE), expecting identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in C:\xampp\htdocs\armadillo\WA_eCart\eCart_PHP.php on line 108
I am attaching the file, I assume the error will also return on my other discount rules.
I assume its a bug since I didnt use any custom coding, I just used the eCart object and my session variables.
How do I fix?
//eCart Rule
//eCart Rule
function WAEC_eCart_AllProductsPercentageDiscount()  {
  $totalDiscount = 0;
  if (true && ((sizeof($this->Items) > 0) && (isset($_SESSION['CouponDiscount'])) && ((isset($_SESSION['CouponType'])?$_SESSION['CouponType']:"") == "1") && ((isset($_SESSION['CouponGroup'])?$_SESSION['CouponGroup']:"") == "1") && (time() >= strtotime("".$_SESSION['CouponValidFrom']  ."")) && (time() <= strtotime("".$_SESSION['CouponValidTo']  ."")))) {
    $totalDiscount += ($this->TotalColumn("TotalPrice") * ".$_SESSION['CouponDiscount']  .");//Result
  return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
.....update...I have found removing some code generated by the eCart Object discount tool to the below works:
[php]
//eCart Rule
//eCart Rule
  $totalDiscount = 0;
  if (true && ((sizeof($this->Items) > 0) && (isset($_SESSION['CouponDiscount'])) && ((isset($_SESSION['CouponType'])?$_SESSION['CouponType']:"") == "1") && ((isset($_SESSION['CouponGroup'])?$_SESSION['CouponGroup']:"") == "1") && (time() >= strtotime($_SESSION['CouponValidFrom']  ."")) && (time() <= strtotime($_SESSION['CouponValidTo']  ."")))) {
    $totalDiscount += ($this->TotalColumn("TotalPrice") * $_SESSION['CouponDiscount']);//Result
[/php]
NOTES: I have removed the following parts:
strtotime("".$_SESSION['CouponValidFrom'] ."") TO strtotime($_SESSION['CouponValidFrom'] ."")
strtotime("".$_SESSION['CouponValidTo'] ."") TO strtotime($_SESSION['CouponValidTo'] ."")
".$_SESSION['CouponDiscount'] ."); TO $_SESSION['CouponDiscount']);
Chris
The issue was with the discount amount... your original code had:
The updated code had:
It shouldn't have been based on the other code you removed... that code appears correct.
Does it all work now? Do you still need help?
Hi Ray, after I modified the code it seems to work. But I just wanted to confirm with you the modifications were correct (or if there is some unseen issue that may arise). from the attached .php file I sent the other day, that file includes the original (non modified code). And its this code thats auto generated by the webassist ecart object when creating the rules. I just want to clarify it all?
Chris
The rule was expecting a number to be entered and you had entered: <?php echo($_SESSION['CouponDiscount']); ?>
I think it would have worked properly if you just had entered: $_SESSION['CouponDiscount'] and that is the difference between the two code chunks.
Hi I am almost sure that I tried it without <?php echo( .... ); ?> part of the code. I could be wrong. I could test that theory I guess :)
