if row value is 'null'
Thread began 8/30/2016 2:20 pm by Kumel | Last modified 8/30/2016 3:15 pm by Ray Borduin | 661 views | 2 replies |
Kumel
i have a row value which is 'null'
<?php if ($row_Products['File']) { ?>
IF value is present display this
<?php } else { ?>
nothing
<?php }?>
So for above if value is null then i get error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1.
This is cause of null value present. how can i fix this?
Kumel
i also tried this : <?php if (is_null($row_Products['File'])) { ?>
same results.
That error is in your recordset code, not in your IF statement. That IF statement should work. What do you have as your SELECT statement?
